2.0L m10'd 316 ***Video added***
Im glad to see this is still going! How long has it been now?
oh rite cool, what came out as the best?Jhonno wrote:they lose you lots of power.. seen back to back tests by SBD
far too long! its been about a year and a half now I think, probably more!rare wrote:Im glad to see this is still going! How long has it been now?
ahhh rite ok, they'll do me for now to get it running
So, it started off as a 1.6 engine that you've bored/stroked to 2.0? I'm liking the twin timing chain setup. What sort of power will it put out?
Cheers!
Cheers!
it started out as a 1.8, ive fitted 2002tii pistons, rods and crank so its stroked to 2.0L. twin timing chain is of a 2002 also.320iSE wrote:So, it started off as a 1.6 engine that you've bored/stroked to 2.0? I'm liking the twin timing chain setup. What sort of power will it put out?
Cheers!
Im hoping for around 150bhp from the engine with a nice amount of torque
bmw02rally
Si,
Have you seen what I'm selling in the parts section?
It would be a safe cool addition to your motor mate!!
Regards
Mark
Regards
Mark
nice one mate, wish I had the money!
Need to spend every bit ive got to get the car rolling now. not far off now. Will be kicking the engine over this week hopefully!
Oh quick question! do you know the rough jet sizes that i'll need for my carbs? I've got no idea.
bmw02rally
Si,
No worries!
I do know the setup you need as I got them written down but I'm knackered tonight as I've been building engines and shit...... I hate Oil!!! I'll post them tomorrow night ok?
Mark
No worries!
Mark
no worries mate, just post them up whenever.
Oil gets everywere dont it!
Im guessing the 02 is getting abit hotter now
bmw02rally
Si,
Pen and Paper?
Chokes: 34
Main Jet: 1.25
emulsion tubes: F16
Aux venturi: 4.50
idle jet: 0.55F8
air corrector jets: 1.70
starter jet: 0.60F5
Accelerator pump jet: 0.40
Accelerator pump back bleed: 0.60
needle valve: 2.00
By the way here's a photo mid build of mine
It looks like I'll have to watch the kids don't get sucked in!!!
regards
Mark
Pen and Paper?
Chokes: 34
Main Jet: 1.25
emulsion tubes: F16
Aux venturi: 4.50
idle jet: 0.55F8
starter jet: 0.60F5
needle valve: 2.00
regards
Mark
Wicked, thanks very much for those mate, know any good suppliers for carb bits? need an accelerator cable bracket and obvo the jets.
am i right in thinking these are weber jets and are the same as dellorto ones? or are all jets the same for both carbs?
Those trumpets look insane!!! whats the spec on that new engine?
bmw02rally
You need to check mate. I'm not sure about Dellorto Carbs.
I would get it running first and then get it on the rolling road. Choose one that's got experience with those carbs and let them mix and match jets and stuff.
My new engine is an ex-Formula3 motor but apart from making over 200bhp I don't know much about it too be honest.
I took the S14 sump of it and its got polished rods and nice lightened crank and also took the rocker cover off and everythings new and says schrick everywhere but apart from that dunno. As long as its f**cking quick I don't really care
The only thing that worries me is the Slide Throttles. Apparently they are great for racing but can be dangerous if you get grit down the intake which jams the throttle open
Not good when travelling fast between trees and grit is quite common in rallying. I've got to do it though just for the noise........ Gotta find some really good filters!!!
ahhh rite ok cool. ill see what i can find out about the dellorto's then. Ive got a rolling road lined up who does all sorts with carbs on caterhams and stuff so that should be all good.
That motor sounds the nuts! just make sure you've got some kind of emergency shut of switch somewere near lol
Hi Mark
Glad you liekthe engine, I had a m10 with the AJEC set upyou have you need to get a high quality lube for the slie, like lithium grease and stripp & lube as part of a service.
Alsoi would look at a air box, I think rally design, or merlin do a uivesial one to go with a cone filter, revir do a carbon one but big Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£Ãƒ”šÃ‚£
Jason
Jason
bmw02rally
Si,
sorry to hijack the thread but Jase if this engine gets me a rally win then you d'man mate
I was thinking airbox but I've got to be careful with Eligibility scrutineers especially if I start doing well. I've got to find out if they had something pre-74 like that......
hmmmm huston i think i have a mojor problem........been reading my book on weber and dellorto carbs. Turns out theres afew different types. Emission and non-emission versions, emission versions cant be tuned properly with performance engines. mine being DHLA 40N seem to be the emission version
Looks like im going to have to change the carbs
bmw02rally
Si,
I never heard that before mate I would have thought with your spec engine you would be okay as long as you have 34mm chokes not 32's?? Emission sidedraughts seems to be a contradition....They all suck gallons of fuel!!
...I would get opinions first from Dellorto dealers.
If you do end up getting different carbs, don't get second hand webers that have been fitted to a Ford Kent engine as they are about as far away from the m10 setup as you can get!!
Regards
Mark
Regards
Mark
jaistanley
Is it worth considering running injection with throttle bodies using megasquirt? Carbs scare me.
Jai
Jai
its goin alright again now, had to concentrate on rebuilding a mk3 polo and a mk2 golf over xmas so havent had much chance to touch the 316
I must have won some kind of award now for longest engine conversion lol.
my dad made it for me
he loves the car lol
*update* finally got round to the bodywork and its almost all done, just abit on the rear panel and valance.
engine wiring is also nearly done so were looking to fire it up next weekend
Just got the front bodywork back together after spraying the valance and under sealing everything:
Andy335Touring
- Contact:
Cool, it will be ready for the summers meets
yeah it will be ready for this years meets
cant wait!
Andy335Touring
- Contact:
How big is that sig pic !!!!
cheers dude, yeah defo spraying the lip! just had to stick it on there as it is too see it all together again.
