Beginning.
Getting there...
Fitting the wheels.
Empty m50.
So what do you think, have i lost my mind?
Thanks mate!AC-SCHNITZER wrote:awesome project![]()
i'm also restauring a e30 but i have a M20 engine
turbo isn't needed i think... just another exhaust en intake
can you post some more pics of the bodywork?
anyway, succes with the turbo!!!
Somewhere between 300 and 400 horses. Don´t wanna raise the boost over 1 Bar (quess that´s around 14 psi or something..?) in the beginning.. I´ve been thinking about getting bigger brakes, but i wanna keep the 4x100 bolt pattern. Any hot tips for the brakes??DieselMeister wrote:Nice work so far - best of luck
What sort of power and torque are you looking for? Bigger brakes?
Joo laitoin huviksi tännekki vähä matskua...Jonsku wrote:Frontbrakes you can get here www.300mm.de ;)
Taitaa sama prokkis olla BTCF:ssä esillä myös
IԚ´m using m50b25 crank and new standard m52b28 pistons and rods. Comp ratio should be bit over 8 with that rod-piston-gasget combination.finny_325i wrote:are you using stanard internalls.Looks like its going to be fun
Well..not exactly.. In cloudy weather, like in that picture, it looks normal 181 diamondblack. But in bright light the pearly violet "jumps out" slightly. But when the violet comes out, it does look littlebit like techno violet.dan_emaps wrote:excellentlooking forward to more pics, so i'm guessing its a darker techno violet?
Me and my mate gonna weld it together. As soon as i have the time to put the top end of the M50 together, weԚ´ll drop it in and start making the manifold. ItԚ´s gonna be a 3/3 pulse manifold, as my GT40 has a divided exhaust casing.dan_emaps wrote:Sweet! what are you doing for an exhaust manifold by the way?
[img]http://
