S52 6sp box onto M52 engine
I'm 99% sure it does but can't say for definate
My reasoning being that the m52 2.8 uses the same gearbox as the 3.0 M3, and i know that the 3.0 M3 box fits onto an S52 evo lump ok.. plus i'm sure i've seen a 6 speed evo box on a 2.8 before!
Hope this is of some help.. and i'd imagine you could use the stock flywheel, not sure about clutch though...
jaistanley
A friend fitted the 6 speed from an E46 (same) to his M50 engined E36 325i recently.
We had to machine the clutch plate from the M3 to fit the flywheel from the M50 because thats what we had.. No doubt you could use an M3 flywheel and full clutch. You'll also need a custom prop and trans mount which I'm sure you know; and possibly gear selector system, talk to Ian about that.
Works OK but the 325i but deosn't suit it at all, The M52 would probably be worse. They both have a large flat torque curve, not suiting the small stacked ratios of the 6 speed. We have the diff from an E36 M3 evo in there though so the engine is totally stifled. Probably be fine with the right diff choice.
So I'm 99.99999999999999% sure it'll fit. But not sure it's worth it unless you get the box for a reasonable price... If so do it!
Jai
Jai
- stevetigger
Here too!DanThe wrote:Ive been considering doing this myself,
Anyone know what the differences are with the gear ratios?
- GermanGorilla
Hi,
The gearbox ratio's in the 5 speed are totally different to the 6 speed
box.
Simple checking would confirm such.
The Getrag 280 6/6 speed box has the common ratios as found in
the E34 540i / E34 M5 6 Speed/ E36 M3 3.2 / E39 M5/ E46 M3.
1 - 4.23
2 - 2.53
3 - 1.67
4 - 1.23
5 - 1.0
6 - 0.83
On the Getrag 280 5 speed found in the E34 M5 5 Speed/
E36 M3 5 Speed/ MZ3 Coupe they are-
1 -3.51
2 - 2.08
3 -1.35
4 - 1.0
5 - 0.81
Mis-information can cause people lots of problems, so please guys, if you do not know then please do not pass comment.
Regards,
The Gorilla.
box.
1 - 4.23
2 - 2.53
3 - 1.67
4 - 1.23
5 - 1.0
6 - 0.83
1 -3.51
2 - 2.08
3 -1.35
4 - 1.0
5 - 0.81
Regards,
The Gorilla.
- GermanGorilla
Hi Aico,
1.0 means direct drive ie - 1 to 1.
The Ratio's are all per BMW.
As stated, the ratios for the Gearboxes are completely different.
Regards,
The Gorilla.
Regards,
The Gorilla.
- Contact:
GermanGorilla wrote:Hi,
box.
1 - 4.23
2 - 2.53
3 - 1.67
4 - 1.23
5 - 1.0
6 - 0.83
1 -3.51
2 - 2.08
3 -1.35
4 - 1.0
5 - 0.81
Regards,
The Gorilla.
But I was trying to compare the 6 speed with an M50/52 5 speed which is direct drive in 5th,
Are these the same?
- stevetigger
M50 Getrag
1- 4.23
2- 2.52
3- 1.66
4- 1.22
5- 1
reverse- 4.04
M50 ZF
1- 4.20
2- 2.49
3- 1.66
4- 1.24
5- 1
reverse- 3.89
1- 4.23
2- 2.52
3- 1.66
4- 1.22
5- 1
reverse- 4.04
M50 ZF
1- 4.20
2- 2.49
3- 1.66
4- 1.24
5- 1
reverse- 3.89
- stevetigger
Looks like a good match Dan!
