hoshy
- E30 Zone Wiki Guru
Sun Jul 20, 2008 7:16 pm
Does anybody know a part number or what the likes of gsf/ecp call them. I can't find on.
Here's what I'm after. I know they're used in various vag applications and probably lots more.
kulvinder
hoshy
Sun Jul 20, 2008 11:00 pm
Ahh good call dude - thank you!
hoshy
Mon Jul 21, 2008 2:20 pm
Oh yeah? PM me then
Supafly
Mon Jul 21, 2008 2:23 pm
if you're not running a lot of boost >1 bar then any of the standard bosch valves should be fine.
If however you plan on regularly going above that then you'll need the one from the audi tt 225bhp model, its a specific year, I think 2003. I'm sure google will throw up the right results with a quick search if thats what you need.
chu346
chu346
hoshy
Mon Jul 21, 2008 4:29 pm
Cheers Supafly - My little charger aint' ever gonna see the right side of one bar so no worries there
Replied Chu
Russianblue
S2Avant
Tue Jul 22, 2008 9:35 pm
It's a bosch 710N valve and they are about £15. Mine loves 1.4 bar of boost on the S2.
hoshy
Tue Jul 22, 2008 9:37 pm
Nice one S2Avant. I'm still having trouble finding one. Chu above decided 10+postage was an insult - lol Sounds about right to me given that they're 15 new.
Jon_Bmw
- Dangerous when thinking
Thu Jul 24, 2008 12:17 am
Is it an ABY engine sir?
1.4 bar of boost is a bit above standard isn't it
280bhp?
I had an audi 100 s4 and loved it. AAN engine, what a great engine that was.
appletree
Thu Jul 24, 2008 6:34 am
cant you got to the scrappies and get one? there on that many cars with the 20vt
hoshy
Thu Jul 24, 2008 9:22 am
Yeah - good call matt but I already had one fail on me (it was 2nd hand) so I thought I'd just try and get a couple of new ones.
Ant
- Retired Team Member
Thu Jul 24, 2008 10:32 am
I have concerns Ash.
I used two HKS SSQ BOV on Racecars and destroyed one very quickly using it as bypass for the SC.
those Bosch vlaves are great on TC cars where they pop open and shut fast, but being held open by the charger would result in rapid failure I think, especially given the high charge temps those Eaton blowers create.
it needs to flow a lot of CFM to dump the unwanted boost reliably dude !
Email FTW
hoshy
Thu Jul 24, 2008 2:54 pm
Hmm. That's not good news for me Ant. If the HKS stuff couldn't cope then I'm sure the bosch stuff will break even quicker
I've thought about a turbo waste gate of maybe an EGR valve but that's quite a bit of trouble for me to be able to adapt - the 25mm dump valves pop straight in to my 60mm/25mm t-piece.. One proved to flow now where near enough at motor way RPMs that's why I was gonna add two. On reflection of what you said I guess I need to re-think.
appletree
Thu Jul 24, 2008 8:21 pm
I'am running a piston type baileys one and its bees spot on seince ive had the car.
bit more expensive to start with but probly cheaper in the long run rather than keep buying the plastic ones
Ant
Thu Jul 24, 2008 9:47 pm
TO be fair, Racecar had much bigger displacement charger so we were on a looser from the outset.
iirc, Dips used twin Baileys on his touring sucessfully.
Email FTW
hoshy
Fri Jul 25, 2008 1:18 am
Hmm... decisions.
Matt what sized ID is your bypass? I found a single 25mm didn't flow enough at motorway rpms and realy kept the charger loaded. Maybe that's just the bosch ones?
S2Avant
Sun Jul 27, 2008 12:54 am
Jon_Bmw wrote:Is it an ABY engine sir?
280bhp?
Indeed it is an ABY - 280bhp and six speed quattro. It has been re-mapped to 1.4 bar and the wastegate spring is standard and in the original position.
Looks like a tdi with a big bumper.
Jon_Bmw
Sun Jul 27, 2008 5:04 pm
S2Avant wrote:Jon_Bmw wrote:Is it an ABY engine sir?
280bhp?
Avants are brilliant sleepers.
