316i touring light resto
Posted: Wed Aug 28, 2019 10:16 am
by Scotland1969
Hi everyone
Thought I would share my latest purchase with you. Picked this 1992 316i up at the weekend, needs a bit of work for an mot, should keep me busy for a while!
Re: New member, new car
Posted: Wed Aug 28, 2019 12:13 pm
by Moz
Hi and welcome!
Looks clean, what is needed for the MOT?
Posted: Wed Aug 28, 2019 1:37 pm
by Scotland1969
It needs a back box, some brake lines, rear subframe bushes, track rod end and a bottom ball joint, it also failed on emissions which I'm hoping is down to the back box, although I think I might put a complete system on including cat. The clutch release bearing is also noisy but I can live with that for a while. The bodywork needs a general tidy up.
The bonnet cable has snapped so at the moment I'm using a screwdriver to open it! I think it also needs a couple of tyres and the I noticed the windscreen washer pipe has split too.
Enough to keep me busy for a while!
Posted: Wed Aug 28, 2019 8:33 pm
by Foe
Yes! Another 316i :thumb:
Hello and welcome too 8)
Posted: Wed Aug 28, 2019 9:03 pm
by shedrool83
Nice project
Posted: Thu Aug 29, 2019 9:07 am
by Steve
Welcome to the Zone, we look forward to seeing more of your project. :thumb:
Posted: Thu Aug 29, 2019 1:26 pm
by Scotland1969
Thanks for the welcome everyone. I'll make sure I post some pics of my progress
Posted: Fri Aug 30, 2019 1:26 pm
by martauto
Welcome to the zone mate :cool: :cool:
Posted: Thu Aug 17, 2023 11:47 am
by Scotland1969
Finally made a start after 4 years!
Posted: Thu Aug 17, 2023 5:04 pm
by martauto
Scotland1969 wrote: ↑
8O 8O 8O 8O
Posted: Mon Aug 21, 2023 4:33 pm
by Moz
That has been a long time in the works! Keep up posted with progress πŸ‘
Posted: Mon Aug 21, 2023 8:23 pm
by Scotland1969
So today I got the handbrake sorted and all adjusted up, fitted the new discs and pads.
Posted: Tue Aug 22, 2023 3:34 pm
by Scotland1969
New trailing arm brake lines today, that's the rear brakes completely overhauled.
Posted: Wed Aug 23, 2023 8:05 am
by Cypriotgeeza
Better late than never!
Start a thread in "Members E30" so you can keep track on your progress. It makes for a good read years down the line :thumb:
Posted: Wed Aug 23, 2023 8:34 pm
by Scotland1969
Bled the brakes this evening and all seems good, no leaks from all my homemade lines and rebuilt calipers! I'll check again in the morning, 🀞
Posted: Thu Aug 24, 2023 6:01 pm
by martauto
Nice one mate :clap: :clap: :clap: :clap:
Posted: Wed Aug 30, 2023 6:01 pm
by Scotland1969
Fitted the new exhaust yesterday but it seems really tight, the tailpipe is touching the rear valance. Maybe it's the cheap pattern backbox I bought!
Today I was going to start it to reverse it into my garage to start on the front end and it would seem the fuel pump has packed, I get 12V at the pump when I crank it but the pump is dead. New one ordered 🀞.
Posted: Sat Nov 04, 2023 5:34 pm
by Scotland1969
New fuel pump sorted the starting problem.
I've now started on the front end, ordered some strut inserts from an online retailer that were supposed to be 51mm but they're 45mm! Very annoying!
Re: 316i touring light resto
Posted: Sun Nov 12, 2023 12:35 pm
by Scotland1969
Just finished rebuilding the front calipers, little bit of paint touching up before they go on the car
Posted: Sun Jan 28, 2024 6:58 pm
by BHadley
They always where hit and miss fitting pattern exhausts, on these, bang on or hits every damn thing…
Posted: Wed Feb 21, 2024 12:30 pm
by Scotland1969
BHadley wrote: ↑
tell me about it! It literally touches everywhere. Can i get rid of the cat ? The car was registered 1/8/92?
Posted: Wed May 29, 2024 11:20 am
by Scotland1969
Failed it's MOT today!
Emissions too high
Fuel tank leak around filler pipe-hopefully just needs cleaned up.
Headlight alignment
Brake line under the bulkhead-missed that one
I've attached the emissions sheet if anyone has any ideas, I suspect the cat is done for but will get some injector cleaner and get it nice and hot for the retest
Posted: Wed May 29, 2024 4:52 pm
by martauto
Am I missing something but the test center has it down as an e36 .
Posted: Wed May 29, 2024 7:14 pm
by Scotland1969
Sadly makes no difference to the emissions it needs to gain a pass.
Posted: Thu May 30, 2024 4:58 pm
by martauto
:cool: :cool:
Posted: Thu May 30, 2024 5:40 pm
by BenHar
Check the manufacture date. It might not need to pass the emissions if it was late registered.
Or put an older engine in. 325i would be good.
Ben
Posted: Thu May 30, 2024 11:43 pm
by Scotland1969
It has a build date of 27/04/1992. It has a CAT fitted.
Posted: Fri May 31, 2024 6:00 pm
by BenHar
I think the cut off was August 92.
Yours should need to be tested to the pre 1 August 1992 standard.
See Table 1 in this document: https://assets.publishing.service.gov.u ... dition.pdf
Ben
Posted: Sun Jun 02, 2024 11:20 pm
by Scotland1969
Thanks for the reply but I can't see any reference to build dates only first used and it was first used on 1st August 1992
Posted: Mon Jun 03, 2024 10:51 am
by flybynite
If it won't pass emissions, then it is telling you the car ain't running right. Go through all the things it could be, plugs, mixture , vacuum leaks etc. Get it running right and the emissions will fall in line.
Sometimes a good 'Italian tune' is all it needs to clear things out but obviously it needs to be on the road first to do that.
Posted: Mon Jun 03, 2024 6:12 pm
by BenHar
It's on page 11.
Ben
Posted: Sat Jul 13, 2024 10:19 pm
by Scotland1969
Replaced the oxygen sensor and it's now got a years MOT!
