My e30 4.0 v8 Drift Project - Wisefab lock kit, BC Coilovers
Posted: Fri Aug 02, 2013 9:35 pm
After selling the e36 328, I decided to do a "proper" build. Made a trip to Driftland to buy an e34 540 with 6 speed gearbox. 2 weeks later bought a e30 318is. The build will be to BDC Spec, so I can compete in a few rounds next year. Its being built my ME, and a mate who owns A.B. Motors.
Car Spec List:-
Vehicle - BMW e30 318is 2 door Coupe
Engine - BMW e34 540 M60B40 4.0 v8 Engine (301 bhp, 292 ftlbs)
Completely Stripped Interior, inc No Heater
Built and Maintained by A.B. Motors
6 Speed Gearbox, standard Clutch/Flywheel
Wisefab Lock Kit (e36 kit, with e30 top mounts)
BC Racing Coilovers (10kg Springs)
Custom CPS Propshaft
E30 325 Welded Diff and Driveshafts
Modified Rear Beam, to allow Toe and Camber Adjustment
A.B. Motors Custom Exhaust
Custom Spray Painted by A.B. Motors
6 Point Roll Cage by WRC Walker Race Cars of Thirsk
Chizfab ”“ Hydro, Boss and Steering Wheel
Driftworks Track Culture Bucket Seats
Driftworks Orange 4 point Harnesses
32 Litre Aluminium Fuel Tank with Sender and Fuel Gauge
Walbro 255 Fuel Pump (Swirl Pot to Engine)
APS 250bhp Fuel Pump (to feed Swirl Pot)
3 Litre Swirl Pot
Japspeed S14 Radiator with Cosworth 1.5 Bar Radiator Cap
Digital Temperature Gauges/Sender in Top and Bottom Hoses
2 x 12”a Electric Fans
E30 Fibreglass Wide Arches
E30 Fibreglass Bodykit (Front Bumper & Skirts)
E30 Fibreglass Rear Bumper
FIA Battery Cut Off
FIA OMP Bucket Seat Side Mount Rails
Power Steering Oil Cooler
JJC Plumbed in Fire Extinguisher
Driftworks Handheld Fire Extinguisher
Full Strongflex Polybush Kit
E36 5 Stud Front Hubs, E36 Compact Rear Trailing Arms with 5 Stud Rear Hubs
TRS Tow Straps
Battery Box behind Passenger Seat
Pics:-
The e30 is a little battered, with overspray all over it. But fuck me is it clean, very clean and hardly any rust at all.
So the stripping commences:-
Decided to remove the car wiring loom, so I can relocate the fuse box inside the car.
Forgot to label the connectors, gonna have fun putting all this back in.
Japspeed S14 radiator trial fit for size.
Currently most of the sound deadening is removed, need to remove sunroof and shit attached to roof. Then its off for Roll Cage.
Spent approx. £6.5k so far on parts and buying both cars.
Current Parts I have, still waiting on many coming.
In the above picture, about £1.5k worth:-
32 litre fuel tank with sender unit
3 litre swirl pot
Fuel Gauge
APS Fuel Pump to feed Swirlpot
Walbro Fuel Pump after the swirlpot
3 x AN8 90 degree fittings
Bucket Seat Adjuster
OMP Seat Frames x 2
e36 328 Propshaft
FIA approved Battery Cut Off with Pull Handle
Wide Arches
Chizfab Hydro, Boss and Steering Wheel
PAS Cooler
Aerocatches x 2
Boot Springs
Japspeed 50mm S14 Radiator
2 x 12" Electric Fans
2 x TRS Tow Straps
Dashboard with mock up panel and switches
Not in pic
e36 Front Hubs, Discs, and Brake Calipers
e36 Compact Rear trailing arms
e36 compact BC Coilovers
*** update 31 July 2013 ***
I now have:-
e36 steering rack
Strongflex full e30 poly bush kit.
*** Update 1st August ***
Got another delivery today:-
2 x 4 point Harnesses
Fire Extinguisher
and dunno wtf that blue shit is ;)
Wisefab Lock Kit, e30 top mounts, rest of kit is e36.
*** update 2nd August ***
Driftworks delivery part 2.
2x Track Culture FIA bucket seats.
I have just about all the parts needed for the build now. Just waiting on hearing when I can get cage sorted.
If you got this far, and not bored. I'd like to know more about wiring, so I can keep it looking OEM. Which plugs or whatever do I need to order from BMW dealer? I'm also thinking about using the 540 brake discs, calipers etc is this possible?
Car Spec List:-
3 Litre Swirl Pot
FIA Battery Cut Off
TRS Tow Straps
Pics:-
3 litre swirl pot
Fuel Gauge
OMP Seat Frames x 2
e36 328 Propshaft
Wide Arches
PAS Cooler
Aerocatches x 2
Boot Springs
2 x TRS Tow Straps
Not in pic
I now have:-
e36 steering rack
Fire Extinguisher
