Page 1 of 2
1990 Zinnobar Red Non Sunroof -Heckblende Fitted and Paint
Posted: Sun Sep 02, 2012 10:25 am
by Alex
Just had my next e30 deliverd this morning, its a 320i shell with a b25 lump complete with no sunroof.
The car itself is in really good nick, its had a full respray a few years back so the paint is really shiney and not the usually faded heap of shit.
its had the footwell jacking pads welded up to a high standard other than that its fairly original, some rust coming through on a lower arch on the passangers side.
Needs alot of time with bits of trim etc as alot of trim has been off and put back on half heartedly, the pop outs have been robbed and the normal windows put back in, again needs finishing off. clips from front grills missing etc, all just simple jobs
Car even comes with 6 month tax and 3 weeks MOT.
Bad part is it needs a clutch master cylinder and sump, both of which i have. Needs a new drivers seat too as its had the fatty treatment.
Plans are to remove the smoked lights, fit chrome kidney grill and black door handles, and fit some 15" bbs, i have a perfect set which were refurbished a couple of years back, should set it off a treat. Also want to paint the lower half of the rear valance black like its suppose to be.
Other than that i think its a good buy
Re: 1990 Zinnobar Red Non Sunroof B25
Posted: Sun Sep 02, 2012 10:58 am
by bigredbmw
popouts werent robbed alex they were returned to the rightful owner which should of been done before it was put up for sale tbh m8 .......
but you have a solid shell and a very nice car there just needs a little bit tlc and will be sorted
Posted: Sun Sep 02, 2012 11:13 am
by capri_rob
Looks like a decent base for a project Alex
Posted: Sun Sep 02, 2012 11:50 am
by Dan320is
That shouldn't take much to change to your tastes Alex, nice buy. Is it a keeper?
Posted: Sun Sep 02, 2012 12:58 pm
by Alex
It is a keeper i hope
Posted: Sun Sep 02, 2012 5:04 pm
by magpie
good purchase alex ,you'll need to find out why the windows only work with the doors open
when you find out what's needed here then the heater blower will probs come back on again and whatever else isn't working inside the car,it'll all be linked to one problem.
or at least i'd like to hope so .
tech1 spoiler
Posted: Sun Sep 02, 2012 5:22 pm
by bss325i
It Is one problem and it's linked to the k7 or k1 (can't remember) unloaded relay and a wire to the starter motor.
Check out the wiring diagrams in the links section
Posted: Sun Sep 02, 2012 8:24 pm
by jaymos
Alex every time I come on here you have a new e30.
Posted: Sun Sep 02, 2012 11:25 pm
by retroboyo
I like it, what wheels are on it at the mo
Posted: Mon Sep 03, 2012 7:43 pm
by harry_p
Yay, zinno
i didnt even know they did zinnobar on a facelift tbh. looks like it should be quite easy to tidy up
Posted: Mon Sep 03, 2012 7:49 pm
by Curr946
if its had an engine change I would check the wiring at the starter first. looks a decent car though well worth the money
Posted: Mon Sep 03, 2012 8:56 pm
by Alex
Thanks for comments, not worried about the wiring just yet, need to spend a fortune on small clips and things at bmw as so much of the trim is missing or not clipped on properly all over the car
things like this really annoy me
The wheels are some 14" replica bbs things, they're coming off possibly tomorrow have a set of almost perfect 15" bbs had the refurbished 3 years ago.
fitted a new sump with new gasket today, was fiddly removing the old sump gasket but some small blades made it easy work, used very small amount of gasket paste too just to be on the safe side.
Fitted a brand new mushroom gear knob with tri stripe and new gear gator today aswell, cost about £15 for the lot posted from bmminiparts, i know its wrong but i love it
the black grill has been took off aswell looks millions better
Posted: Wed Sep 05, 2012 8:11 pm
by Alex
Re:
Posted: Wed Sep 05, 2012 8:26 pm
by retroboyo
Looking very smart now, your cleaning efforts have inspired me to give mine a good clean
Re:
Posted: Wed Sep 05, 2012 8:28 pm
by Alex
Thanks, every e30 i have has to look like brand new inside, makes it a so much nicer place to be in
got a 2 year old tech 2 wheel to go in it aswell which will set it off nicely
Re:
Posted: Wed Sep 05, 2012 8:35 pm
by retroboyo
It's a car to be proud of, I will look forward o seeing any updates
Re:
Posted: Wed Sep 05, 2012 8:36 pm
by magpie
that battery looks familiar
Re:
Posted: Fri Sep 07, 2012 6:38 pm
by Alex
magpie wrote:that battery looks familiar
Does it come with a warranty its fooked
Re:
Posted: Fri Sep 07, 2012 9:50 pm
by magpie
i used to drive the calypso turd up the drive in 1st gear,engine not running but off the cranked starter motor with that battery,it was brand new 4 mths ago.no wonder it's f00ked
EDIT......
Those wheels
Re:
Posted: Sat Sep 08, 2012 6:44 pm
by Alex
I will get a new one before the pod think the genuine bmw one off the touring is buggered been flat for months
Re:
Posted: Sat Sep 08, 2012 10:22 pm
by Kedge
Nice work Alex, love how clean you get interiors. Are those wet vacs expensive?
Re:
Posted: Sat Sep 08, 2012 10:28 pm
by bigredbmw
looking good .nice and clean inside
Re:
Posted: Sat Sep 08, 2012 11:55 pm
by Alex
Kedge wrote:Nice work Alex, love how clean you get interiors. Are those wet vacs expensive?
Not sure its my mums
I bought that hand tool for it however, think it was £120 however its about 5 years old or so. Probably get them alot cheaper now
Picking up some new springs and front struts tomorrow as its on cut springs and one shock is leaking. worst handling e30 ive ever driven if i'am honest
Posted: Tue Oct 09, 2012 7:08 pm
by Alex
Re:
Posted: Tue Oct 09, 2012 7:46 pm
by retroboyo
We need Brianmoooore
Posted: Tue Oct 09, 2012 8:02 pm
by johnl320
Fuel tank breather, comes to an end under the bonnet anyway, unless there is a carbon cannister fitted which is very unlikely
Re:
Posted: Tue Oct 09, 2012 8:07 pm
by Alex
Ah right, is it not fuel return line ?
Will it fail the MOT ?
Re:
Posted: Tue Oct 09, 2012 8:23 pm
by Kedge
The fuel feed and return pipes are the two thicker ones to the right and run in the same clips as the brake pipe.
MOT man might not like it, not sure. If I was you I'd cut it back at the tank end and remove everthing from there forward and then just fit a short bit of rubber pipe by the tank to vent there, this is how it is set up on the prefacelift cars.
Re:
Posted: Tue Oct 09, 2012 8:25 pm
by Alex
Sounds like a plan, least its nothing important
Re:
Posted: Tue Oct 09, 2012 8:30 pm
by capri_rob
Is that just the breather pipe to the front of the car ?
They're about £20 from BMW IIRC
Posted: Tue Oct 09, 2012 8:36 pm
by johnl320
I got an advisory for a corroded one so did what Kedge has posted
Re:
Posted: Tue Oct 09, 2012 9:19 pm
by e30topless
Kedge wrote:If I was you I'd cut it back at the tank end and remove everthing from there forward and then just fit a short bit of rubber pipe by the tank to vent there, this is how it is set up on the prefacelift cars.
+1 that's how early turds are,
Re:
Posted: Tue Oct 09, 2012 9:43 pm
by Rtaylor2208
Alex is that not the breather pipe to the fuel tank? Can't really tell for sure from the picture, is it snapped or missing altogether?
Re:
Posted: Tue Oct 09, 2012 9:44 pm
by Rtaylor2208
Ah too slow
Re:
Posted: Wed Oct 10, 2012 4:49 pm
by Tan91
This is a nice turd! loving the Tech1 spoiler as well. Brilliantrot?
Have you done a fair search for rust?
All in all liking it so far and the soap for interior good work, looking pretty mint inside!
