1990 e30 325is Restoration Plans
Posted: Tue Feb 10, 2009 4:03 am
by Murd
Re: 1990 e30 325is Restoration Plans
Posted: Tue Feb 10, 2009 5:51 am
by 323iNathan
Holy $h!t best of luck with that!
You'll have your work cut out for you
. If that were my car I'd
, still its great to see someone willing to spend the time to fix one up.
Posted: Tue Feb 10, 2009 11:55 am
by skipunda
yer dude that aint right, quality car otherwise though. Good luck!
Posted: Tue Feb 10, 2009 12:31 pm
by bmwe30mtech
Hi,
I would strongly recomend you replace those rear quarters, as they will need so much patching otherwise. I would also recomend new outer inner rear arches and rear panel. It is essential that this is done properly though, or they will rust out at the seams in a few years time. All joints between panels must be very well done to last in the long term!
Find some good used doors, they are cheap and its not worth welding rusted ones. Same goes for front wings and valance, either get good used ones or new ones but they cost about 160 per wing and 150? for the front valance. Same goes for the wing mirror - not worth grinding back.
Have you pulled down the headlining on the roof to check the sunroof tray? They can rust in here. Get the dash out and check the bulkhead also.
Great work by the way
They always look so good with the kit on ay!
Here are a few pictures of my sport with the rear and front panels off last summer for some inspiration, your car is saveable but its going to be a huge ammount of work!
Best of luck with it.
Re:
Posted: Tue Feb 10, 2009 2:24 pm
by ricey46
Holy sh1t...that does have a wee bit of the rusty stuff!! As Paul(bmwe30mtech) says make sure you check the bulk head incase there's some rust up there aswell, this is mine...
Also have you thought of a reshell?? I know It would mean your car wouldn't be a true Sport but it may be cheaper and easier?? Josh Hocking is selling a red two door at the mo not sure if it's worth a look? A bit ironic coming from me considering what I'm doing but just a thought.
Good luck which ever route you chose, it'll look ace when finished
Inspired
Posted: Tue Feb 10, 2009 2:38 pm
by Murd
Thanks for the advice Guys will get the carpets and headlining out as you suggested Ricey.
Wow - bmwe30mtech - what an undertaking - I like the approach though. It is quite appealing going down that road, knowing that the entire panel is solid. - I never knew until coming on here that these rear inner arches were replacable - Nice. How Much are the rear wings ? also I heard that you can buy battery boxes from BM does anyone know about this.
Its all going to come down to how skilled I am on the end of a welder - should be arriving tomorrow.
Not sure I'll get much done as Im probably going to be heading away soon as I work offshore. Gear myself up for when i get back.
Ricey - You mention a reshell. I take it you mean with a donor car (2nd hand).
Are there differences between sport and non sport shells ?
Excuse my ignorance
Thanks again for the advice guys !
Re: Inspired
Posted: Tue Feb 10, 2009 2:54 pm
by ricey46
Murd wrote:Thanks for the advice Guys will get the carpets and headlining out as you suggested Ricey.
Excuse my ignorance
Battery boxes are available from BMW not that expensive I think,
As for the reshell, yeah using a second hand shell, it may not have as much wrong with it needing fixing so therefore an easier solution, but no there's no difference between Sport and non-Sport shells, just when you change shell the chassis number will change and won't be a Sport one, making it not genuine.
Any questions just ask, someone will know the answer on here!
Re: Inspired
Posted: Tue Feb 10, 2009 2:57 pm
by Daf318is
The red looks surprisingly shiny considereing how much tin-worm you have!
Bodywork is something i steer clear of, admire you for undertaking this! - Good luck
Scuttle
Posted: Tue Feb 10, 2009 3:14 pm
by Murd
I have a new scuttle from BMW Germany with my VIN stamped. I don't suppose its legal to have that fitted to another shell though ?
Re: Scuttle
Posted: Tue Feb 10, 2009 3:26 pm
by SUMPCRACKER
Keep that to yourself!! Do what is the most sensible/easiest/cheapest.
I would go for another shell if its a lot better but I think its only Legal if its a new shell.
Its not realy ringing as long as the good shell isnt stolen.
I have done this a few times but it seems to worry some,but as no one will know the difference when the car is built I wouldn't worry.
Re: Scuttle
Posted: Tue Feb 10, 2009 4:18 pm
by oakey
I have a very solid brilliant red shell if your interested
You can have it for next to nothing if you collect it.
Re: Scuttle
Posted: Tue Feb 10, 2009 4:33 pm
by SUMPCRACKER
That is a good example of what E30 zone is about!! (legal issues aside
Re: Scuttle
Posted: Tue Feb 10, 2009 4:40 pm
by ricey46
Oakey saves the day, much better option!!
Oh and what have you done to the photos??
Best not to delete them once on Photobucket.
Re: Scuttle
Posted: Tue Feb 10, 2009 5:39 pm
by leeparkes
Where's the pics gone
Photos
Posted: Tue Feb 10, 2009 7:37 pm
by Murd
Yeah - My pics were too big so just resizing them so that they load up quicker
Re: Photos
Posted: Sun Feb 15, 2009 2:58 pm
by Nogaro325
Holy sh1t and i thought mine was bad
good luck with it
Re: Photos
Posted: Sun Feb 15, 2009 4:17 pm
by Jon_Bmw
Amazing how nice it looks in the first few pictures. Good old tech2 kit huh!
Most owners bury their heads about the underneath of the kit, so its good to see you haven't, well done.
Battery box is circa £40. Reshelling it would seem a good option, but spend ages viewing them as I doubt any car is 100% rust free at this age. Ringing the car, would seem a slightly dogey, but do-able IMO. Its not as if its a stolen car is it.
Re: Photos
Posted: Sun Feb 15, 2009 5:39 pm
by jbh
I'm surprised it as bad as it is... my tech1 i thought was needing a bit of welding but yours has defo got a bad case of rust.. i wish you luck on whatever route you take
where you located ?
Re: Photos
Posted: Mon Feb 16, 2009 2:50 am
by Murd
Yeah - West Coast Highlands - The ol' Sea Air doesn't do me any favours nor the neglect of the past 5 years.
My MIG welder arrived - fek its not as easy as I thought - I was going to post a few pictures of my practice welds on here but I'm not going to further embarass myself. Need a little more fine tuning - Wire speed and technique - I was using pure CO2 but I've heard that Argon/CO2 mix produces a much nicer weld ?? My welds would maybe get me a job in a collander factory.
I'm now thinking of going down the reshell route - where less of the outcome will depend on my welding skills - Respect to the other guys on here Paul(bmwe30mtech) etc. Any free lessons in MIG welding ??
I'll persevere ...
Re: Photos
Posted: Mon Feb 16, 2009 3:24 am
by poolnoodle
Best of luck!!!
Not wanting to sounds smart (in fact, the opposite) but how do cars in th UK get so rusty? I have never seen an E30 with that sort of rust and am yet to find anything but slight surface discolouring under the boot rubber on my E30.
I had always assumed that BMW had good rust proofing but obviously it is to do with road conditions. Salt? I don't think cars that were exported to Australia were rust proofed any different.
A mate of mine has several E30s sitting in a paddock in various states of disrepair and despite being like that for years, in the weather, none have the rust that I see on this site.
Re: Photos
Posted: Mon Feb 16, 2009 10:10 am
by jbh
Murd wrote:Yeah - West Coast Highlands - The ol' Sea Air doesn't do me any favours nor the neglect of the past 5 years.
was thinking that with the pics... my black tech1 spent its life up there it was just as bad as yours.. before you go any further with the welder take the dash out and look behind there
Re: Photos
Posted: Mon Feb 16, 2009 2:54 pm
by barryj
Thats a long way gone mate, I have a clean relativley rot free 320i that will make a great car to re-shell into. Its £150.
I don't think there is going to be much left of your shell by the time you chase the rust right back from the obvious holes.
Re: Photos
Posted: Mon Feb 16, 2009 4:02 pm
by Murd
Yeah its official - re-shells the way ahead - trying to source one at the mo....
Mind you - big improvement on the welding front today - had the co2 turned up fully must've been about 7 bar - this was my main problem when I reduced it to say 3 bar immediate improvement, nice neat welds not dis-similair to those pictured on
http://www.mig-welding.co.uk - good site that.
Re: Photos
Posted: Tue Feb 17, 2009 4:03 pm
by E30Gheko
poolnoodle wrote:Best of luck!!!
Correct me if I'm wrong but I was under the impression that the climate in Australia is well... rather hot?
Conversly the weather in the UK is, for want of a better word, shite. It rains, and rains and rains. It's cold in the winter which means that the council salt our roads only adding to the corrosion misery.
Can you ship us over some tidy shells from Oz please?
BTW Murd, re-shell all the way with this one. That's a very big welding mountain for a novice welder. If ur in no rush though, what the hell? Good luck dude.
Re: Photos
Posted: Tue Feb 17, 2009 4:17 pm
by leeparkes
You have your work cut out,ive never seen a rust hole under the wing mirror before!
Got the New Shell !!!!
Posted: Sun Mar 22, 2009 2:21 pm
by Murd
Re: Got the New Shell !!!!
Posted: Wed Mar 25, 2009 3:22 pm
by ricey46
Nice I'm glad you went with the reshell option, as you would have had one hell of a job on your hand other wise
This shell seems much better, just the usuall places of rust, good luck with it, i'm still trying to find a body shop
Posted: Wed Mar 25, 2009 3:23 pm
by jbh
ricey46 wrote:Nice I'm glad you went with the reshell option, as you would have had one hell of a job on your hand other wise
what welding you needing done to your car Paul
sorry for going off topic
Posted: Wed Mar 25, 2009 3:33 pm
by oakey
Glad you got it back ok! I didn't realise all that crap on the boot floor was part of a repair
I thought it was some crap that was spilt in the boot
I'm also surprised at how gone the "jacking points are" they looked good at a glance.
Good luck with it all dude
Posted: Thu Mar 26, 2009 10:30 pm
by parkin10
good luck with your project
Posted: Fri Mar 27, 2009 10:23 pm
by MartC
Defo think you've chosen the easiest option there mate. I'm on a welding marathon and believe me it does get a bit tedious after a while. Especially if like most of us you don't have a workshop full of metal fabrication stuff.
Keep us up to date with pics, doing a very good job so far
