pimp my headlining
Posted: Sat Apr 26, 2008 8:22 pm
by Cloggy Saint
Today I finally got around to finishing my touring's headlining. On the whole I'm pretty pleased with the way it turned out, there're a few wrinkles here and there but nothing too obvious. I just hope the glue withstands the summer heat.
Re: pimp my headlining
Posted: Sat Apr 26, 2008 8:26 pm
by doctorspike
want to do mine man
Posted: Sat Apr 26, 2008 8:39 pm
by march109
Starch it too before you put it back. the starch keeps it stiff hich in turn stops it stressing the join on the glue
Posted: Sat Apr 26, 2008 8:44 pm
by Cloggy Saint
Really? Afraid I don't know too much about starch, is it liquid
Posted: Sat Apr 26, 2008 8:55 pm
by mattG
Looks good from here, one of the jobs on my todo list as I've currently got the CSL look
March will the starch affect the nap & could you still brush it after it is starched?
Posted: Sat Apr 26, 2008 9:59 pm
by dips346
LOOKS ACE ,told you its not hard to do
Posted: Sat Apr 26, 2008 10:50 pm
by Cloggy Saint
Cheers Dips, and thanks for the advice. Like I said, I'm not convinced it's going to hold, so if it comes down I'll try it with a lighter, thinner material.
Posted: Sun Apr 27, 2008 10:36 am
by toby
Nice job. I bet that will be fine, the heavier material notwithstanding.
I may do that to mine when it sags back down again. Thanks for the inspiration.
Posted: Sun Apr 27, 2008 11:03 am
by barryj
Is it alacantara?
Posted: Sun Apr 27, 2008 11:08 am
by Cloggy Saint
It's fake suede, but looks the part.
Posted: Sun Apr 27, 2008 11:50 am
by citizensnips
does the headlining mount to some sort of board that attaches to the roof, thats what it looks like from the picture or is it like the ones with the thin metal strips going across the roof?
Posted: Sun Apr 27, 2008 5:57 pm
by Cloggy Saint
The original set up is a rigid fibreglass board, then a foam layer and then the outer material.
Posted: Sun Apr 27, 2008 6:57 pm
by oze30
Mine stuck, but I rushed mine and faffed about, and it needs to be re stuck or hair dyed back up.
Not a difficult job, just fiddly.
Posted: Sun Apr 27, 2008 7:08 pm
by dips346
mine is fine but i did use the thinner verson
Posted: Sun Apr 27, 2008 11:23 pm
by oze30
Depends on the glue you use as well.
Posted: Wed Apr 30, 2008 2:45 pm
by bmwscorpion
On this topic. how easy does the roof lining come out of a touring. ? do you have to remove the rear glass??
any help would be appreciated.
Posted: Wed Apr 30, 2008 2:53 pm
by Cloggy Saint
No glass removal necessary! Remove grab handles, check control, sun visors, interior lights etc. Pull the rubber door seals down. There are four clips at the rear, one either side of the tailgate hinges. Once these are released it's just a case of giving the headlining a tug backwards to free it from the four points holding it up in the middle. All will become clear once it's out!
Posted: Wed Apr 30, 2008 2:55 pm
by bmwscorpion
Thats excellent thank you , it was one job I really didnt want to do. but sounds easy enough..
Cheers..
Posted: Wed Apr 30, 2008 9:39 pm
by E30BeemerLad
good work Ed, I'm waaay too lazy for recovering the lining, a can of spray paint would be my chosen method
Posted: Thu May 01, 2008 1:56 pm
by cros
Out of interest, what are the extra holes in your headlining for?
(On the left and right over centre of the boot section)
Posted: Thu May 01, 2008 2:17 pm
by dips346
cros wrote:Out of interest, what are the extra holes in your headlining for?
its for the dog guard clips for the rear blind
Re:
Posted: Thu May 01, 2008 11:50 pm
by oze30
Just realised he had the easy option.
NO SUNROOF!
Re:
Posted: Fri May 02, 2008 7:16 am
by Cloggy Saint
It helps, in more ways than one!
