E30 M3 CAD model
jondrift
Sun Dec 16, 2007 9:15 pm
Hey all, a few weeks ago there was a CAD modelling thread on here, which inspired me to have a quick go at an e30 m3. Its still a working progress as i havent managed to render it in the better program, but its coming along nicely. What do you think...?
oakey
Sun Dec 16, 2007 9:38 pm
Very good mate 8) When will it be finished?
gazm3
Sun Dec 16, 2007 9:51 pm
When finished I would like a CAD copy.
Use it with work, well done.
jondrift
Mon Dec 17, 2007 10:34 am
should be finished (rendered properly) in a week or so, but the actual wire model is finished already. What would you be using it for mate?
UweM3
Mon Dec 17, 2007 11:26 am
very good work! I have a 3D printer. Would you mind sending me the model?? I have a SWX license and can read IGES, sat ot STL. I can offer to print a small model for you (with your "modifications" if you have time to add some) in return.
jondrift
Mon Dec 17, 2007 12:05 pm
sounds pretty swish! i take it you would just want the wire file for that and and not need any shaders/materials?
UweM3
Mon Dec 17, 2007 12:35 pm
what format is the wire file? What CAD package was used to create it?
Do you know what a 3D printer is?
gazm3
Mon Dec 17, 2007 12:37 pm
Would like just to print off at work.
I use Auto-cad at work (Shopfitter)
I did a bit of Wire frame/solid modeling At Uni some time ago.
Cheers Gareth.
jondrift
Mon Dec 17, 2007 9:13 pm
the prgram i used to make the model itself is called alias studio tools 13.5, and the file is just called alias.wire
i think as it is youl need alias yourself to open it, but i know there is a way to save it in a different format. What format would you need??
not really sure what a 3d printer is no! Does it cut the shape out of a cube!??
I am happy to send you guys the file, but out of interest what you doing with it?
UweM3
Tue Dec 18, 2007 8:24 am
that's a 3D printer http://www.zcorp.com/Products/3D-Printe ... spage.aspx
I need an STL file for that. Or IGES, SAT, parasolid. Everything but wire :D
jondrift
Tue Dec 18, 2007 10:28 am
that looks pretty cool!
im pretty sure i can save it to one of those file types. Ill post back up on here when ive added a few finishing touches. Does the model need a floor or cvan it be a hollow shell? And do you create the colours and textures at your end, or do i have to do that here??
cheers
oakey
Tue Dec 18, 2007 4:08 pm
UweM3 wrote:that's a 3D printer http://www.zcorp.com/Products/3D-Printe ... spage.aspx
Mate. Would you be able to do some 3d prints for me (obviously in exchange for some spondoola)? What material does it make the models from?
Do you personally own it? Why did you not tell me this earlier :D
And @jondrift. If you dont mind a bit of constructive criticism, I suggest, that the sides of the car looks too flat (vertically). If you know what I mean :mad: Apart from that- damn near pefect :D
jondrift
Tue Dec 18, 2007 7:31 pm
yea i did notice that myself, it may be the case of the next rendering program i put it on will fix it, as most of the shape can be defined by the shading, illl have a play and will re post when its finilised :)
UweM3
Tue Jan 08, 2008 8:47 pm
PM sent
