Ive fitted a Merceded e300 24v 3.0 turbo diesel mated to a 6 speed Mercedes gearbox
With help of some great friends over at Sump-scuffers we custom made a 6 point rollcage
Who needs gussets when your cage fits properly
Also running a Wilwood pedal box, ready for future upgrades
Current spec
Up front
E46 lower arms
shortened e30 struts with mk1 golf inserts and weld on coilovers
E36 m3evo steering rack with 4mm lock spacers
Out rear
Med case diff with 3.64 ratio Welded needs alot taller
E36 double wing diff cover with custom mounts
Suframe and diff mounts are solid steel and aluminium respectily which also lift the subframe removing the need for adjustment tabs
Hybrid Mercedes/ Bmw propshaft
Custom engine and gearbox mounts for the usual engine swop
Lots more but i thinm thats enough for one post
