325 sport starting problems?
t16turbo
Sat Apr 12, 2008 1:32 pm
Hi,
my 325 sport does not start very well from hot or cold?
when I try to start it, it will crank over for upto 5 seconds then fire up and run fine?
if I turn it off and try again straight after its been running it starts fine! any ideas?
BMracing
Sat Apr 12, 2008 4:03 pm
Mileage?
I notice your user name, what sort of Rover do you have? I'm a fan of those engines.
Max
Sat Apr 12, 2008 4:17 pm
Mine does the same although to be fair it starts from cold fine most of the time. General opinions seem to be that it could be down to a leaky injector or faulty cold start injector.
I am going to change the normal ignition components ( dizzy cap, rotor arm, plugs ) as well as cleaning the throttle body etc to see if this makes an improvement before I start messing with the injectors.
