wet drivers side carpet - HEELLLPPPP!
Posted: Tue Apr 08, 2008 12:53 pm
I have a wet carpet just in the drivers footwell and can't work out where its coming from. I have felt around the carpet and don't think it is coming from the centre console area as this is dry. The plastic membrane between the door panel and door is fine so its not that.
I'm sure its rain water as it's not losing coolant.
I've had the wheel arch liner off and the inner wing is fine, as is the inside of the scuttle. The 'elephants trunk' is also clear.
Could it be the drivers side front sunroof drain thats the problem? How do you get access to it to see if it is split/dislodged, and where does it come out. I've fed some curtain wire down the hole but can't work out where it ends up.
Any suggestions gratefully received as I am stumped. I don't want to have to revert to a full car cover!!
