325i starting problems
Posted: Mon Apr 07, 2008 5:57 pm
by nasir325ic
Hi,
I have a problem in starting my car, ill explain how it came about.
The car was being driven on motorway, and it started misfiing, i.e intermittant powerloss, then all of a sudden it cut out , when i fired it up it would stay on for a few seconds then cut out.
it got recovered by RAC,
sometimes when i fire it up it just doesnt turn over, and sometimes it just doesnt do any thing, it seems like no petrol going through, but why does it fire up every now and then.
i was told it could be the rotor arm, i changed and cleaned the dizzy cap, but still the same,
what else can i try.
Re: 325i starting problems
Posted: Mon Apr 07, 2008 6:16 pm
by mash320i
check your fuel pump mate if you havnt already
Posted: Mon Apr 07, 2008 6:50 pm
by nasir325ic
fuel pump sounds ok i think?
it whirrs when i turn the key,
and cuts off when the engine cuts out
Posted: Mon Apr 07, 2008 7:11 pm
by nasir325ic
could it be the fuel filter
Posted: Mon Apr 07, 2008 7:12 pm
by mash320i
are you getting fuel at the rail?
Posted: Mon Apr 07, 2008 7:16 pm
by nasir325ic
i really dnt know, how can i check?
Posted: Mon Apr 07, 2008 7:17 pm
by nasir325ic
dont know wat happened there but this is wat i meant to say
' i really do not know, how can i check?'
Posted: Tue Apr 08, 2008 10:59 am
by nasir325ic
anyone any ideas?
Posted: Tue Apr 08, 2008 11:09 am
by abelai
crank position sensor?
Posted: Tue Apr 08, 2008 11:38 am
by nasir325ic
where is that
Posted: Tue Apr 08, 2008 2:43 pm
by abelai
On a later m20 its on the front pulley under dissy cap. Also check for faulty relays on the nrs front inner arch there should be 3 under a plastic cover.
