symbols meanings on instrument cluster in dash
Posted: Sat Mar 29, 2008 9:02 pm
by Aziz
Hi
One of the lights on my instrument cluster is flickering on the colour is red.
Looks like this (O)
It the one between the hand brake symbol marked (P) then is the one I'm having the flickering with it look like this (O) then its the exclamation mark in brackets I.e (!).
Its flickering on the off and I don't know what its for and what to do to rectify the problem??
Thanks in advance guy.
Aziz
Re: symbols meanings on instrument cluster in dash
Posted: Sat Mar 29, 2008 9:25 pm
by march109
Its brake pad warning light.
Pads might not be gone though, inspect them. Often the brake pads are replaced and the brake pad wear sencers are not.
Posted: Sat Mar 29, 2008 9:31 pm
by Aziz
Thanks March.
I will inspect them tomorrow morning.
Posted: Sat Mar 29, 2008 10:06 pm
by Brianmoooore
220 ohm resistor!
Posted: Sat Mar 29, 2008 10:10 pm
by march109
Brianmoooore wrote:220 ohm resistor!
Sorry brian are you saying its a different problem or that a 220 ihm resistor will replace the the brake pad wear sencers?
Posted: Sat Mar 29, 2008 10:14 pm
by smithy318i
http://www.e30zone.net/modules.php?name ... page&pid=7
Posted: Sat Mar 29, 2008 10:17 pm
by smithy318i
Since the light is flickering rather than always on, its probably the dry joint problem on the instrument cluster rather than a 'sensor'.
Posted: Sat Mar 29, 2008 10:20 pm
by march109
Gotcha might check mine then too since my instrament panel is out anyway.
Posted: Sat Mar 29, 2008 11:44 pm
by Aziz
Thanks guys will go through the stages.
Posted: Sun Mar 30, 2008 12:21 am
by BeemerShmeemer
ah thats what the light is! i must check mine then. does it haven sensors on the back? or just the front. mines a mix and match of afew cars so dont realy know what its ment to have :(
Posted: Sun Mar 30, 2008 12:23 am
by march109
IIRC front right and rear left have sencers. If you are facing the car.
Posted: Sun Mar 30, 2008 9:35 am
by smithy318i
march109 wrote:IIRC front right and rear left have sensors. If you are facing the car.
Front left and rear right calipers have sensors.
If you have rear drums, you only have a front sensor.
Posted: Sun Mar 30, 2008 10:40 am
by Brianmoooore
march109 wrote:IIRC front right and rear left have sencers. If you are facing the car.
Or front left and rear right, if you are facing forwards.
All lefts/rights, forwards/backwards, front/rear on any car are taken from as they would be sitting in the driver's seat.
