Fuel Filter
Posted: Wed Mar 26, 2008 9:30 pm
by mattsbmw
Can anyone tell me where the Fuel filter is on a 1988 E30 325i and how i change it safely.
thanks
Re: Fuel Filter
Posted: Wed Mar 26, 2008 9:34 pm
by Yaninnya
It is on front ot the tank (on the left side), under the car.
How to change it safely? Don't smoke during the work. :wink:
Jan
Re: Fuel Filter
by fuzzy
should be under the floor on the passenger side below the front seat, in line , couple of jubilee clips job done but be aware of the flow direction indicated by an arrow on the filter.
Re: Fuel Filter
Posted: Wed Mar 26, 2008 10:45 pm
by Gwynleym10
Make sure you de- pressurise the system first. Have the engine running and take either the fuel pump relay out or the fuse ( I think fuse 16). If you don't you will waste a load of fuel..
Re: Fuel Filter
by mattsbmw
fuzzy wrote:should be under the floor on the passenger side below the front seat, in line , couple of jubilee clips job done but be aware of the flow direction indicated by an arrow on the filter.
This is me being a bit thick, so is it underneath the car or under the passenger seat.
Re: Fuel Filter
Posted: Wed Mar 26, 2008 10:48 pm
by irish320i
Its under the car and it is better to remove the fuse or really as you ll end up sprayed in petrol it you dont
Cheers Alan
Re: Fuel Filter
Posted: Wed Mar 26, 2008 10:52 pm
by danman2k
i did mine on the weekend, i have same car. start engine and remove fuse 11, let engine cut out and replace the fuse. it will cut off the pump and in turn the fuel. the pump is underneath the car, back passenger door. there is probably a black cover over it that needs removing. :)
Re: Fuel Filter
Posted: Thu Mar 27, 2008 12:17 am
by Geoff
Or you could always get a pair of mole grips and clamp the hose. I did that when i replaced mine. Spilt a splash of fuel agreed but did neither of the above suggestions. I guess there are many ways to skin a cat huh!
Good luck dude. :cool:
Re: Fuel Filter
Posted: Thu Mar 27, 2008 10:18 am
by TRANSPORTER
take out fuse 11 and start the car, it will run for max of 5 secs then cut out, although I wouldnt put the fuse back in until I had finished the work. Just in case.
Re: Fuel Filter
Posted: Thu Mar 27, 2008 12:15 pm
by AlexBaur325
Is it in the same place on a facelift B20 car?
Re: Fuel Filter
Posted: Fri Apr 11, 2008 1:16 am
by beemerbird
In my 89 325 it's under the brake fluid resevoir. Fuse out, run the engine till it dies, battery neutral off, change it, then wonder why you haven't worked on your own engine before! :D
Re: Fuel Filter
Posted: Fri Apr 11, 2008 9:28 am
by capri_rob
beemerbird wrote:In my 89 325 it's under the brake fluid resevoir. Fuse out, run the engine till it dies, battery neutral off, change it, then wonder why you haven't worked on your own engine before! :D
Same here ( I Think ! ) bolted to the suspension strut on the passenger side - need to remove the airbox to get at it properly and its still a bit of a pig to remove - out of my 4 E30's don't think any of them had the fuel filter under the car - they've all been mounted in the engine bay !
Re: Fuel Filter
Posted: Fri Apr 11, 2008 12:33 pm
by mattsbmw
Thanks for this, will have a look this afternoon and see if i can locate it.
thanks
