overheat,,
tigalima
Tue Mar 04, 2008 4:21 pm
hi all,,
i'm newbie here btw,, need you guidance ,,lol
ok, straight to the point, my car is an e30 m40
i have an overheating problem,, don't know where it came from
last week i've changed my radiator and the van,,
there are no leaks in the hoses, and i think the thermostat is allright cause i've changed it with the new one , about six month ago,,
but yesterday is happening again,, overheating,
well, i need your opinion,,
thnx
zaust
Zone day release
Tue Mar 04, 2008 5:20 pm
Could be an air lock and need's bleeding. And check out the viscus fan clutch.
M30 Tech 1 Touring on gas.
andyaskew
Tue Mar 04, 2008 5:22 pm
I've just been talking to the garage about mine and he said they are 'a pig' to bleed properly.
Probably that.
Tue Mar 04, 2008 5:44 pm
Overheating under what circumstances? A lot more detail required!
tigalima
Wed Mar 05, 2008 1:46 am
Brianmoooore wrote:Overheating under what circumstances? A lot more detail required!
well, it's overheating if i got stuck in heavy traffic,,
yesterday, 10 minutes after i started up the engine the heat indicator turns to red,, strange huh? it's the first time hapening like that,, is it because i used it to travel out of town 2 days ago??? it's pretty far,, around 200 km,
btw i've changed the viscus fan clutch,,
HairyScreech
Wed Mar 05, 2008 2:25 am
is the thermostat stuck closed? blocked radiator?
Wed Mar 05, 2008 9:42 am
tigalima wrote:btw i've changed the viscus fan clutch,,
Have you checked the new one works? These viscous units can fail, if they are stored for any length of time flat. They must be stored on edge.
tigalima
Wed Mar 05, 2008 1:21 pm
well, my van is running smoothly since i got it changed,, but i'll check it later,,
i hope it's just an air lock and everything is ok,, couse i spent lot of money on my car,, and it Broke My Wallet (BMW) lol
