Overheating problem
Posted: Tue Feb 26, 2008 12:46 pm
Hi, got an overheating problem on my 1990 316i.
Basically, needle starts off on cold as normal, gets to midway very quickly and very soon gets to red.
I first noticed it after i did an oil change and was running the engine to get the oil through. After about 15mins i noticed there was water dripping quite quickly out from under the radiator somewhere. I checked the rad and couldnt see any cracks on the outside, checked the small pipe going into the reservoir (which is at the front of the engine attatched to the rad) and it could have possibly been coming from there - not too sure.
Thing is though, i've tried to recreate the situation, had the engine idling for about 20 mins but not had any water dripping. I checked the coolant level, it was fine. Pipes seem firm which suggests there is water going round...
Thing is, (which makes me think its the thermostat) i cant seem to get any hot air out through the blowers. The fan is going round, seems to be constantly on, but all i get is cold air, even when the needle is at the red.
Anyway, i've checked numerous posts and people are mentioning the Viscous Coupling on the fan, water pump, the Thermostat or an air leak, i was wondering if someone had the same problem so i could narrow it down before i fork out loads of cash for someone to look for me!!
Any ideas????????????
