rear electric windows
Posted: Sun Feb 24, 2008 8:07 pm
by hiace
help,jus converted my rear manual windows to electric,only problem is that they dont work when used from the rear switchs in the door cards but work fine when operated from the center console. ? have i missed out a fuse or relay.
Re: rear electric windows
Posted: Sun Feb 24, 2008 8:10 pm
by Cha_Maan
Did you connect them up to the main loom at the B-Pillar?:D
Do the rear switches light up?
Check the child cut-off switch isn't in top left of your console.
Also try swapping the switches with the one's from the fronts.
Posted: Sun Feb 24, 2008 8:12 pm
by Brianmoooore
Cha_Maan wrote:Check the child cut-off switch isn't in top left of your console.
Have you even fitted the child cut off switch?
Posted: Mon Feb 25, 2008 3:09 pm
by hiace
hi, yes they were connected to the main loom b-pillar. and no the rear switchs dont light up. their is no child cut off switch in my console,so is this sum thing i will have to find and fit .
Posted: Mon Feb 25, 2008 3:57 pm
by Brianmoooore
hiace wrote: is this sum thing i will have to find and fit .
It's a square push button switch. Connector will be waiting for you under the console, cutting lines are marked underneath the console.
The rear switches won't work without it.
Posted: Mon Feb 25, 2008 8:34 pm
by Cha_Maan
I can send you one if you don't have one. They're worth nothing and available from BMW or eBay for pence.
Good luck cutting a neat square out of that console foam shite - better off seeing if you can find a console that was cut for 4 x power windows in the first place.
Posted: Tue Feb 26, 2008 12:56 am
by hiace
thank's guys,i have got the switch of chris-w and will fit it later this week and see how i get on. once again big thank you.
