rear electric windows
Did you connect them up to the main loom at the B-Pillar?:D
Do the rear switches light up?
Check the child cut-off switch isn't in top left of your console.
Also try swapping the switches with the one's from the fronts.
- Brianmoooore
Have you even fitted the child cut off switch?Cha_Maan wrote:Check the child cut-off switch isn't in top left of your console.
- Brianmoooore
It's a square push button switch. Connector will be waiting for you under the console, cutting lines are marked underneath the console.hiace wrote: is this sum thing i will have to find and fit .
The rear switches won't work without it.
I can send you one if you don't have one. They're worth nothing and available from BMW or eBay for pence.
Good luck cutting a neat square out of that console foam shite - better off seeing if you can find a console that was cut for 4 x power windows in the first place.
