Gearbox Mounts - pain to change?
Cha_Maan
Sun Feb 24, 2008 7:23 pm
Where are they located exactly?
Is a 318iS and 318i the same work?
Dull question I know but need to know.
Chars.
Chris-W
Sun Feb 24, 2008 7:25 pm
Under the gearbox :)
Towards the back. Same work on both those models, and not much work at that.
Cha_Maan
Sun Feb 24, 2008 7:27 pm
Gearbox out job?
How long to do - sorry I have never done any work there and have no idea.
Have ordered the bits so just need to attack armed with some info.
wullie325i
CAUTION - unreliable trader!
Sun Feb 24, 2008 7:37 pm
just jack the car up and have a look it will just about explain itself!
Cha_Maan
Sun Feb 24, 2008 7:40 pm
Great!
I love 5 min jobs!
Sun Feb 24, 2008 7:45 pm
Even the back of the gearbox is light enough to lift by hand!
Sun Feb 24, 2008 9:25 pm
what's the best thing to do when you can't get one of the cross member bolts undone where it bolts to the chassis.
I assume the end of the bolt that sits in the rail on the floor has a "square" top to it which sits in the rail?
I am trying to get the cross member off ready to pull out the engine & box but the nut on the driver side is just spinning the whole bolt. Have tried jamming a screw driver into the rail whilst undoing the nut but the whole lot is turning.
Any ideas other than getting the angle grinder and destroying the nut? Or is that the best option?
Theo
Sun Feb 24, 2008 9:36 pm
I just levered down on the braket with a tyre lever putting loads of tension on it so it would'nt rotate. It's really annoying when this happens though :-x
tomtomiS
Sun Feb 24, 2008 9:56 pm
simon13 did mine for me a fortnight ago, didnt take him very long :D
Sun Feb 24, 2008 10:01 pm
Angle grinder will sort it, if levering down won't. New bolt's not expensive.
You may even be able to slide the mount along to where the bolt drops out, once the gearbox rubbers and the other bolt are off.
