need urgent help with cruise control
Posted: Thu Feb 14, 2008 7:34 pm
by DJ_B4L
jus fitted my cruise control to my car i need to know which slot the speed signal wire goes in on the green plug that clips on the instrument cluster
i have a auto car one wire is already going to one of the slots think this is for the auto gearbox.
need urgent help as im going to take the car to work tomorow so need to put the speedo back in thanks
Posted: Thu Feb 14, 2008 7:47 pm
by DJ_B4L
also does this plug in the pic below need to be wired back into it self on a auto car
Re:
Posted: Thu Feb 14, 2008 8:48 pm
by Templ8e30
First off, pretty sure you can use any of the sockets on the left hand side of the green speed signal block (left hand as if it's in place on the car).
Yes, those 2 cables need to be shorted on an auto.
Looks like a pre-facelift loom, the connector is different on facelift looms.
Cheers,
Iain T
Re:
Posted: Fri Feb 15, 2008 12:52 am
by DJ_B4L
cheers for the reply mate
i have shortned the 2 red/green wires i assume this is the clutch switch wire (normally connected to a clutch switch on a manual)
i connected the speed signal wire on to the right hand side on the green plug (as your looking at it stright on from behind the cluster
i connected two other wires i had that were green/red and purple/white to the brake switch wires
i connted the brown to earth
and one other wire that i had which was blue/brown to a blue/brown wire in the car i tried to test the cruise control it didnt seem to do anything
any idea what would be wrong?
all the wires and cables are connected
Re:
Posted: Fri Feb 15, 2008 7:51 pm
by DJ_B4L
any1???
Re:
Posted: Fri Feb 15, 2008 8:12 pm
by matttouring
P.M sent
Matt
Re:
Posted: Fri Feb 15, 2008 8:40 pm
by matttouring
You have E-mail bud hope it helps you out
Matt :D
Re:
Posted: Sat Feb 16, 2008 12:00 pm
by DJ_B4L
cheers for that mat i havnt had a chance to look at it yet
any one have any idea if i need to check anything else
