Signal light blink speed problem ???
Posted: Thu Feb 14, 2008 12:03 pm
by wks79
hi guys ,
just noticed when driving the car today ,
all the sudden , all my right signaling are blinking double time quicker than the left signaling (lef which is normal )
anyone experienced this before ?
cheers.
Re: Signal light blink speed problem ???
Posted: Thu Feb 14, 2008 12:16 pm
by rj
This is usually an indication that an indicator bulb has blown, so firstly check all relevant bulbs on the right hand side of the car.
Posted: Thu Feb 14, 2008 12:19 pm
by wks79
its actually on the meter cluster that's blinking quicker. the right signal one. do i still check the bulb in there?
Posted: Thu Feb 14, 2008 12:29 pm
by BreadBin
It will be one of your exterior indicators - try giving which ever one is not working a good thump as this will usually get it going and is the sign of a corroded connection.
Posted: Thu Feb 14, 2008 12:45 pm
by wks79
ok will try that
thanks .
Posted: Thu Feb 14, 2008 4:49 pm
by wks79
thanks Breadbin , alas, ..the rear tail light bulb on the right was a bit out of the socket (maybe bumps on the road caused it)
a quick refitting of the bulb sorted it out
e30's always seem to amaze me with the amount of innovation it has, even until this day .
guess its a way for the car to tell us that the bulbs/connections are knackered. (fast blinks )
no wonder i kept getting the finger from drivers behind me , when i signal right . they cant see my signaling
well might try some LED panel that might fit the signal lights , should last significantly longer than conventional bulbs eh .
they sell them here in some car accesory shop , for about 5 malaysian ringgit. which isbout .... 35p ?
will post some pics when i do fit em on the car.
