m20 2.5 cranks
Posted: Mon Jan 07, 2008 11:33 pm
by blitz877
is there any difference between the auto crank and manual crank? iv got the possibility of a 2.5 auto so just wondering what diff there is
Re: m20 2.5 cranks
Posted: Mon Jan 07, 2008 11:41 pm
by trigger
spigott bearing for 1, not sure if any other.
Re: m20 2.5 cranks
Posted: Mon Jan 07, 2008 11:42 pm
by JazzMan
No idea, but I just pulled one out of a manual - click the image for a high res one if you want to compare:
Re: m20 2.5 cranks
Posted: Tue Jan 08, 2008 4:23 pm
by ed325i
No they are the same.
you just need to put the bearing in the end.
Re: m20 2.5 cranks
Posted: Tue Jan 08, 2008 4:25 pm
by blitz877
on the end of the crank or end journal?
Re: m20 2.5 cranks
Posted: Tue Jan 08, 2008 7:11 pm
by koos
In the hole at the g/box end of the crank.
Re: m20 2.5 cranks
Posted: Tue Jan 08, 2008 10:05 pm
by Brianmoooore
Check the input shaft spigot diameter on the gearbox you are going to use, before you buy the bearing.
