Removing Light Washers
Posted: Sun Jan 06, 2008 8:10 pm
by sigtouring325i
Hi,
I need some help in removing the headlight washers, I really don't like
them and want them gone.
I am finding it really hard to remove them and just wanted some tips/advice.
Sorry if this has been posted before, but couldn't find an answer on the search
Sig
Re: Removing Light Washers
Posted: Sun Jan 06, 2008 10:55 pm
by jcjdavis1
Hi its very easy to do.
Lift flap and undo bolt to take blades off (8mm)
take grills off,take water hose off
take off rear cover on headlamps
take 2 (10mm) nuts and bolts from bracket holding on wiper motors(spanner one side +socket set other)
unplug wiper motors and take out,wrap plugs up to keep watertight
unplug electrical connector on headlamp wash pump
if you wish to take stops of headlamps you have to take headlamps off to access screws at rear of lamps
put grills back on ,job done.I think
