Hey
I'm just building my 2.7 at the moment.
What timing belt are you 2.7 guys using?
i.e: would it be from a 525e or a 320i?
what timing belt do you use for a 2.7?
Reppin' NZ e30's.
Ant
- Retired Team Member
- Contact:
stock M20B25 @ 127 teeth dude.
the only time the belt becomes an issue is using a decomp plate of more then 2.5mm
dont forget , if you have the block decked or a heavy head skim a vernier pulley will be required
lemme know on the vernier, I'll need to add that to your order dude
Email FTW
I'm using the 731 head, forgot to mention that.
So I shouldn't need a vernier a?
Antony.
Antony.
Reppin' NZ e30's.
