HELP!!!, Interior map light mirror fitting, HELP!!!
Posted: Sun Dec 09, 2007 11:08 am
by joeboy
Hi can any body tell me how to fit the above mirror I,ve looked, and cannot see how to start taking the front head lining out to get into the mirror fixing,let alone running the wireing,any help, please, joeboy. :?
Posted: Sun Dec 09, 2007 12:05 pm
by ROC
This might help you out mate http://e30.bmwdiy.info/lighted-mirror/index.html
Cheers,
Rich
Re:
Posted: Sun Dec 09, 2007 1:10 pm
by joeboy
Hi And thanks Rich, forgot to say the motor I,m putting the mirror into is a 318i (c reg),so it does not have a oc so cannot pull the oc out, there for, its the front panel piece with the sun visors on,thanks again,joeboy :?
Re:
Posted: Sun Dec 09, 2007 1:19 pm
by tomson
The headlining doesnt need to be removed!
Re:
Posted: Sun Dec 09, 2007 2:33 pm
by SPADGE
To remove the black panel around the sunroof switch you need to take the 2 screws out underneath the wind deflector that comes up when you open the sunroof.
Also pull off the door seals around the top front corner as its tucked around the door apperture.
Remove both sun visors and their clips.
Thats about it from memory.
Re:
Posted: Sun Dec 09, 2007 11:02 pm
by joeboy
Cheers Spadge, going to give this a try(when it stops raining of course),by the way any idea how get the wire down to the passenger foot well,(thats where I was told it goes)regards,joeboy. :) :)
Re:
Posted: Mon Dec 10, 2007 12:20 am
by Brianmoooore
Windscreen pillar side trim pulls straight out at the top (spring clip) and then has to be lifted straight up to unhook a clip near the bottom.
