HELP!!!, Interior map light mirror fitting, HELP!!!
joeboy
Sun Dec 09, 2007 11:08 am
Hi can any body tell me how to fit the above mirror I,ve looked, and cannot see how to start taking the front head lining out to get into the mirror fixing,let alone running the wireing,any help, please, joeboy. :?
ROC
Sun Dec 09, 2007 12:05 pm
This might help you out mate http://e30.bmwdiy.info/lighted-mirror/index.html
Cheers,
Rich
joeboy
Sun Dec 09, 2007 1:10 pm
Hi And thanks Rich, forgot to say the motor I,m putting the mirror into is a 318i (c reg),so it does not have a oc so cannot pull the oc out, there for, its the front panel piece with the sun visors on,thanks again,joeboy :?
tomson
Sun Dec 09, 2007 1:19 pm
The headlining doesnt need to be removed!
SPADGE
Sun Dec 09, 2007 2:33 pm
To remove the black panel around the sunroof switch you need to take the 2 screws out underneath the wind deflector that comes up when you open the sunroof.
Also pull off the door seals around the top front corner as its tucked around the door apperture.
Remove both sun visors and their clips.
Thats about it from memory.
joeboy
Sun Dec 09, 2007 11:02 pm
Cheers Spadge, going to give this a try(when it stops raining of course),by the way any idea how get the wire down to the passenger foot well,(thats where I was told it goes)regards,joeboy. :) :)
Mon Dec 10, 2007 12:20 am
Windscreen pillar side trim pulls straight out at the top (spring clip) and then has to be lifted straight up to unhook a clip near the bottom.
