brake light is on on the check board
Posted: Wed Dec 05, 2007 5:41 pm
by devonboye30
hi my brake light has com on on the check board on the roof,thing is all the bulbes are fine and working.wot do u think it might be
Re: brake light is on on the check board
Posted: Wed Dec 05, 2007 8:52 pm
by Brianmoooore
There only has to a problem with the brake lights for a fraction of a second for the light to come on and stay on until the ignition is turned off and back on.
Get someone to follow you while you are driving to see if they are behaving themselves.
Posted: Wed Dec 05, 2007 9:02 pm
by HenryM3
Had this problem before as well, cleaned all the contacts, in the end I changed the bulbs even though they worked ok, never had a problem since.
Posted: Fri Dec 07, 2007 5:40 pm
by devonboye30
yeh thats what i did and all good now
Posted: Fri Dec 07, 2007 6:48 pm
by Brianmoooore
There are at least three different versions of the rear cluster lamp holders.
On one version, the circuitry and lamp holder contacts are made from solid round wire. Eventually these wires wear such a deep groove into the solder bases of the lamps, that electrical contact is lost.
Posted: Fri Dec 07, 2007 8:10 pm
by 320imoredoor
Ye i had dat prob aswell. Didnt no wat 2 do so i hit da break pedal hard & da lite went out!! SORTED
Posted: Sat Dec 08, 2007 10:35 am
by jacko
320imoredoor wrote:Ye i had dat prob aswell. Didnt no wat 2 do so i hit da break pedal hard & da lite went out!! SORTED
Das gd bruv innit!!!!!!!!!!
Posted: Sat Dec 08, 2007 12:27 pm
by Gibson
yes meesh u no dat i iz sayin innit bruv hardcore gangsta massive i iz from da staines GHETTO Blud!
Posted: Sat Dec 08, 2007 10:06 pm
by 320imoredoor
WHAT!!!!!!!
Posted: Sat Dec 08, 2007 10:51 pm
by E30Mark
320imoredoor wrote:yes meesh u no dat i iz sayin innit bruv hardcore gangsta massive i iz from da staines GHETTO Blud!
WHAT!!!!!!!
You bloody started it!
Please learn to speak / type in English !
