floor carpets wet
Posted: Tue Nov 13, 2007 11:08 pm
by ocram
hi got a prob with my m3 my carpets are wet on hte front sides of the car all window sunroof and door seals are new and dont seem to leak. any adv woud be hepfull .
Re: floor carpets wet
Posted: Tue Nov 13, 2007 11:31 pm
by grantfk10
Hi Ocram, and welcome to the Zone - I saw your M3 at the Green Wellie? Not sure I can help with your problem, but I'm sure someone will be along soon with loads of tips. :wink:
Posted: Tue Nov 13, 2007 11:34 pm
by deane30
Hi Mate, i just posted basically the exact same question at the same time as you. random huh?
http://www.e30zone.net/modules.php?name ... 188#906188
Posted: Tue Nov 13, 2007 11:37 pm
by beardymat
could be a few things this
leaking heater valve/heater matrix. found behind the glovebox on rhd cars but im not sure about the m3, think its still on the lh side of the car.this tends to make one side of the car wet and not the other.
scuttle drain blocked, look under bonnet on the bulkhead near the battery tray and you should see a little plastic elephant trunk looking thingumy.they get blocked and the water backs up and goes through the air intake for the heater.
gromet where wiring goes through the bulkhead, rust is also an issue here so its deffo worth a look.
rust around the jacking points (look under the car behind the front wheel and you will see a 3" square metal plate) this allows the front wheel to splash water up into the car.
thats the ones i can remember but its probably one of the top two.
