slight click from matrix?
Posted: Tue Nov 06, 2007 5:51 pm
by dazleeds
ok when i put my engine back in a few weeks ago, i went to bleed the coolant and found my heater wasnt working at all fan not even turning
so i bypassed the matrix to bleed the engine
anyway wanna get it sorted and how it should be,
when i turn heater on nothing happens except for a slight click sound coming from behind the das?
any ideas??
cheers
Daz
Re: slight click from matrix?
Posted: Tue Nov 06, 2007 5:56 pm
by kam-325i
The click from behind the dash/glove box area should be the heater valve.
Posted: Tue Nov 06, 2007 6:58 pm
by jam172
Could also be air still trapped in the heater pipes.
Re:
Posted: Tue Nov 06, 2007 7:00 pm
by old_skool
Make sure you connect the matrix stubs up the right way daz, or the heater valve wont work 'proper like' AND Brian will come and get you
Re:
Posted: Tue Nov 06, 2007 7:15 pm
by Templ8e30
What he said ^
Cheers,
Iain T
Re:
Posted: Tue Nov 06, 2007 7:23 pm
by dazleeds
at the moment the matrix is bypassed
but did double check at the time
theres just nothing when you turn the heater at all no motor spinning etc
Re:
Posted: Tue Nov 06, 2007 7:36 pm
by chief
had a very similar thing with mine
if with the heater on (but not spinning) in the dark do the lights slighly dim as you hear the click sound
if so its the heater motor draining the power.
disconnect the fuse for the heater and you will confirm this if there is no click
HTH
Re:
Posted: Tue Nov 06, 2007 10:14 pm
by Brianmoooore
Heater is the bit that gets hot. FAN is not the heater!
As chief says. Not uncommon for the motor to seize after twenty years of no lubrication.
