325 HEAD WITH 320I BOTTOM END AND GEARBOX
Posted: Tue Nov 06, 2007 3:18 pm
by biffaboy00
hi there a m8 of mine said i can have his old engine with the 325 head and the rest as a 320i would this be anymore powerful then the 320i engine iv all ready got
Re: 325 HEAD WITH 320I BOTTOM END AND GEARBOX
Posted: Tue Nov 06, 2007 3:23 pm
by Ziggy
No. I doubt it'd even be as powerful as a standard 320i - the 325i head won't work well on a 320i block at all.
Posted: Tue Nov 06, 2007 4:24 pm
by Jhonno
325i head wont work with a 320i bottom end
Posted: Tue Nov 06, 2007 4:59 pm
by m-dtech
Jhonno wrote:325i head wont work with a 320i bottom end
320i head and 325i head both work on an ETA block which has flat pistons and is similar ?
i cant see anything clashing ?
Posted: Tue Nov 06, 2007 6:36 pm
by ed325i
The eta has bigger bores same as a 325.
The 320 has smaller bores so the 325 head will not work.
Posted: Tue Nov 06, 2007 7:13 pm
by Templ8e30
ed325i wrote:The eta has bigger bores same as a 325.
It would fit and work but not very well, compression would be down on a 320i head due to the shap of the combustion chambers.
Also the inlet ports will be the wrong shape for a 320i inlet manifold as well as being too large losing even more torque.
Bad combination.
Cheers,
Iain T
