Air locks..
Posted: Sun Nov 04, 2007 1:56 pm
by Hath
Right, starting to become a pain in my tetther end...
every so many miles i am having to bleed my coolant system, and everytime there is alot of Steam/hot air produced i am doing it porpley everytime i know this as my boss has already done it to ym car twice and ive done it three times, whats the cause of getting air locks? split pipes acting as one way valves letting air into the system? any other ideas im not loseing water as far as i know so grr! any help wud be most appreciated
Re: Air locks..
Posted: Sun Nov 04, 2007 2:03 pm
by JONUK
What engine?
Re: Air locks..
Posted: Sun Nov 04, 2007 2:04 pm
by Hath
318is M42 sorry my bad
Re: Air locks..
Posted: Sun Nov 04, 2007 2:26 pm
by JONUK
Just checking your process for filling the system here. When the car was originally filled with coolant was it on a good flat and level surface and the bleed screw left open until coolant run out? Did all the hoses get hot and the system cycle before you replaced the expansion tank cap?
Re: Air locks..
Posted: Sun Nov 04, 2007 2:29 pm
by Hath
expansion tank is situated in the radiator? basicaly when i put the engine in my turing.. filled it with water on my drive, lef to get to temperature, then bleed teh air out untill non bubbly water comes out of bleed valve then keep water topped up whilst screwing nipple back up..? do you reccomend pressure bleeding it ie sticking a hose strigh in the expansion? im contemlating droppingall the water out of it and starting again
Re: Air locks..
Posted: Sun Nov 04, 2007 2:52 pm
by JONUK
The 318is expansion tank is the small header tank you are filling up with coolant on the side of the radiator. Did you have the heater temperature control set all the way to hot when you started to fill the system?
Re: Air locks..
Posted: Sun Nov 04, 2007 3:45 pm
by Hath
no?
Re: Air locks..
Posted: Sun Nov 04, 2007 4:21 pm
by JONUK
Ah there's your problem then, unless the heater temperature control is set to hot the heater matrix will not get filled and will just be one big air bubble. Get draining :D
Re: Air locks..
Posted: Tue Nov 06, 2007 3:15 pm
by TRANSPORTER
Interesting, would this tecnique be the one to use on an M20 325i engine aswell, as I changed the thermostat on mine the other day and didnt do all that.
Re: Air locks..
Posted: Tue Nov 06, 2007 5:42 pm
by rj
Yes it applies to the 325i too.
Turn the temp regulator to fully hot and switch on the ignition whilst you are refilling the system.
