That engine mount....photos.
Posted: Thu Nov 01, 2007 12:44 am
by tomstickland
Well, the engine mount finally failed today, when driving over a speedbump coming out of the scrap yard where I'd just been to pick up.....a new subframe. I managed to drive about 40 miles with the engine only held in by one mount. The steering was very heavy because the remains of the mount were touching the rack rod arm.
This photo shows all that remained of the driver's side engine mount bracket:
More photos at:
http://www.flickr.com/photos/92961862@N ... 820115531/
Re: That engine mount....photos.
Posted: Thu Nov 01, 2007 3:54 pm
by whipsey
Posted: Thu Nov 01, 2007 3:59 pm
by bobafett
Flipping heck ! A polite way to say FCUK ME !
Posted: Thu Nov 01, 2007 7:31 pm
by tomstickland
Rather oddly, even with the engine wobbling around it made very little noticeable difference to the handling! Once it finally broke and the mount touched the rack, then that was noticeable since the steering was heavy.
I've just bought a Z3 rack to replace it with though.
Posted: Thu Nov 01, 2007 8:42 pm
by Karan
must have just rested onto the subframe on the sump
Posted: Fri Nov 02, 2007 10:27 pm
by tomstickland
Correction; I've been out on some decent B roads today and the handling is much better. Oddly, the rear seems more planted. Must be something to do with weight transfer. The car is sublime!
Posted: Tue Nov 06, 2007 9:56 pm
by driverstu
was it easy to change.i have to change mine on my 325sport this weekend got any tips.drivers side
Posted: Wed Nov 14, 2007 10:20 pm
by tomstickland
It's not too bad. Support the engine via jack/axle stands under the sump. I had some difficulty getting it all to line up, sorted by loosening all of the bolts and wobbling the engine around.
Posted: Thu Nov 15, 2007 10:09 am
by SamE30
I did both of mine not so long ago....... not too bad......getting to the bolts from above can be abit trick especially if the engine has moved a lot.......... as said you will probably need another person to wiggle the engine about as you lower it back down so it sits correctly!
