16 inch BBS 4 stud......
Posted: Sun Oct 28, 2007 7:07 pm
by DanThe
What are these from? 16 inch BBS 4 stud, et 20
They have been on an E30 with 205/50 rubber, I havnt seen them on the car though, the spoke pattern has a curve inwards onto the dish.
Re: 16 inch BBS 4 stud......
by SCOTT325SE
pics
Posted: Sun Oct 28, 2007 7:09 pm
by DanThe
I would if I could :)
Posted: Sun Oct 28, 2007 7:30 pm
by gareth
aftermarket BBS? what are the markings?
i had some ET12 8.5J16 5 stud ones a while ago with a massive dish :cool:
Posted: Sun Oct 28, 2007 10:14 pm
by DanThe
Found some on the bay in 15 inch format
http://cgi.ebay.co.uk/Alloy-Wheels-Vw-G ... dZViewItem
VW fitment wheels I take it?
Any good for an E30 with the et 20 offset?
Posted: Sun Oct 28, 2007 10:16 pm
by Hath
IIRc, they in turn are golf fitment? and are fairly rare and worth alotta mullah.. had a golf mk2 come into work wiht a set on .. teh wheels were worth more than the car..
Posted: Sun Oct 28, 2007 10:27 pm
by DanThe
I would need some 8mm spacers to get them to fit right?
What about spigot rings?
I quite fancy them as they are not seen very often, not to mention the 16 inch business 8)
Posted: Sun Oct 28, 2007 10:30 pm
by SCOTT325SE
with et 20, they'll go straight on
Posted: Sun Oct 28, 2007 10:43 pm
by DanThe
Will they drive ok though?
Only reason I ask is my 16 inch Alpina's are et 28 :?
Posted: Sun Oct 28, 2007 10:46 pm
by maxfield
It's also to do with the width of the wheel, but as Scott said, they will go straight on.
Posted: Sun Oct 28, 2007 10:58 pm
by gareth
DanThe wrote:I would need some 8mm spacers to get them to fit right?
wrong. it's the other way round. 8mm spacers will make a ET20 wheel into ET12.
ET20 should be fine, though a little coser to the arches but not by a massive amount
according to this page, ET15 to ET18 is right. probably baased more on looks than handling so being halfway between should be ok
http://www.alloywheelsinternational.com/BMW.html
DanThe wrote:What about spigot rings?
E30 = ÃËa72.6mm
Golf = ÃËa57.1mm
from here: http://www.alloywheelsinternational.com/VOLKSWAGON.html
(nice spelling for VW!!!)
machining will be needed on the wheels if they don't have spigot rings that you can removed / swapped
Posted: Sun Oct 28, 2007 11:02 pm
by maxfield
E30 is 57.1mm. E30 M3 is 72.6mm. IIRC.
by DanThe
Cheers Gareth, I understand now, et = the measurment from the hub face to the centre line of the wheel
How do you think they will look? Bling or ming? :)
Posted: Sun Oct 28, 2007 11:06 pm
by SCOTT325SE
standard 15" BBS wheels are et24. 4mm is sod all buddy!
Posted: Sun Oct 28, 2007 11:09 pm
by gareth
DanThe wrote:Cheers Gareth, I understand now, et = the measurment from the hub face to the centre line of the wheel
that's it!
i think bling :D not too sure on the curved spokes though... a bit 13" nova wheel style...?
by SCOTT325SE
TECHNICALLY, the WHEEL will always be et20. Using spacers will change the EFFECTIVE offset though.
Posted: Sun Oct 28, 2007 11:11 pm
by gareth
yeah, alright! i know! :?
some people.... :wink: :D
Posted: Sun Oct 28, 2007 11:16 pm
by SCOTT325SE
:kiss:
Posted: Sun Oct 28, 2007 11:24 pm
by Nelly
fight, fight, fight!!!!!!!!!! :poke:
Posted: Sun Oct 28, 2007 11:55 pm
by HairyScreech
could they be from a mx5? iv seen a few around here with them on.
Posted: Mon Oct 29, 2007 6:35 am
by DanThe
I know Mazda's had BBS but 16 inch?
Posted: Mon Oct 29, 2007 9:08 pm
by DanThe
Well, I went with cash in hand and they turned out to be 15 inch :roll:
Seems we had confused each other in between a set of Alpina's and E39 16 inch BBs :mad:
Was a nice thought though :(
