steering noise help please
Posted: Fri Oct 26, 2007 11:08 pm
by reaz12345
hi, when i start my 325i cab i get noise from the steering wheel when i turn it. it seems to be coming from the engine bay of the car. i think there might be air in the power steering pump but not to sure
any ideas?
thanks
Re: steering noise help please
Posted: Fri Oct 26, 2007 11:17 pm
by lance1a
Most PS systems make some noise when on full lock, or early if cold. just check the fluid level, make sure there are no leaks and that the belt is tight.
Posted: Fri Oct 26, 2007 11:21 pm
by reaz12345
what belt i didnt know there was 1?
cheers
Posted: Fri Oct 26, 2007 11:31 pm
by lance1a
the belt that drives power steering pump (at the bottom of the motor) is crank driven. look at the bottom of the front of the motor for a small pump with two large rubber hoses coming from it. make sure that it's not too loose. Make sure the pie/segmented reservoir on the left hand side of the car near to the brake servo is full and that the fluid is still clean (reddish).
Posted: Fri Oct 26, 2007 11:56 pm
by reaz12345
thanks lance1a
Posted: Fri Oct 26, 2007 11:57 pm
by lance1a
no worries mate.
regards
rob
