318is into 316 touring teathing problems, please help.
Posted: Tue Oct 16, 2007 9:11 pm
by jam172
I have recently fitted the an IS engine into my touring, all went really well except i don't seem to be able to bleed the air out of the cooling/heater system.
I can hear it gurgling and the heater keeps going cold, at idle it gets warm again :roll: is there a set method, i am using the bleed screw on the expansion part of the rad, can anyone help please?
Re: 318is into 316 touring teathing problems, please help.
Posted: Tue Oct 16, 2007 9:15 pm
by Brianmoooore
Fill the coolant tank right up, pull the top heater pipe off at the bulkhead and let the air out.
Posted: Tue Oct 16, 2007 9:24 pm
by jam172
Brianmoooore wrote:Fill the coolant tank right up, pull the top heater pipe off at the bulkhead and let the air out.
Excellent, thanks for that, i will try tomorrow, do i get it up to temperature first, and whilst its running or not?
Posted: Tue Oct 16, 2007 9:41 pm
by Brianmoooore
Cold and stopped, unless you fancy a trip to A&E tomorrow as well! Although I must confess that I've done it on a partly warmed engine that's just beginning to pressurise the system.
Posted: Tue Oct 16, 2007 9:51 pm
by jam172
:eek: ok stone cold tomorrow morning, thanks again :o:
Re:
Posted: Tue Oct 16, 2007 10:03 pm
by royale30
Bimmers seem to be a bugger for bleeding the cooling. I had the same problem when I changed the water pump on my e34 last year. Took me ages to get it fully bled, I had to keep doing it for a couple of days to really sort it, it was as if air was getting stuck in the block and working its way round?
Posted: Wed Oct 17, 2007 7:54 pm
by jam172
:( Still cannot expel air from the cooling system, any more suggestions?
Re:
Posted: Wed Oct 17, 2007 7:56 pm
by Simon13
Jam have you got the heater turned on speed 4, the temp on warmest and all 3 vents open?
Posted: Wed Oct 17, 2007 8:08 pm
by jam172
Yes i have, and i can hear the air clicking throgh the heater pipes inside the car, the heater is hot, but the minuite you drive off up the road the heater goes cold again :evil:
If you then stop in traffic it gets hot again and you can hear the air lock once again :cry:
It's driving me :mad:
Re:
Posted: Wed Oct 17, 2007 9:23 pm
by Brianmoooore
Put the heater pipes on the correct way around!!!
Tee hose goes to top stub pipe.
Re:
Posted: Thu Oct 18, 2007 7:21 pm
by jam172
Brianmoooore wrote:Put the heater pipes on the correct way around!!!
:o: All ok now, thanks.
Re:
Posted: Thu Oct 18, 2007 8:16 pm
by tandino
Whoops :P
