Cannot get gearbox into gear when weather is cold!
Posted: Mon Oct 15, 2007 12:30 pm
by kboiling
Hi There
My son has had a 318is since the spring. When the air temperature starts to get down towards freezing (like this morning!), it can take 10 minutes of trying to get into first or reverse. It's been fine all summer, but was the same on cold mornings earlier in the year. He thought it had cured itself, but it must just have been that it hadn't been that cold all summer. Anybody had the same problem, or know what it might be?
Many thanks!
Re: Cannot get gearbox into gear when weather is cold!
Posted: Mon Oct 15, 2007 1:36 pm
by jbh
bit of a long shot but id try renewing the clutch fluid
Posted: Mon Oct 15, 2007 1:41 pm
by chrisr29
Mine does the same. I just stick it in gear before I start it.
It may be worth trying synthetic gear oil......although I have since noticed that the nylon cup that holds the gear lever in has worn quite a lot allowing the gear lever to lift when you push it forward. Dunno if this has any bearing.
I suspect that it's really down to wear in the gear box.
Posted: Mon Oct 15, 2007 1:46 pm
by daimlerman
'er indoors moans constantly about the change from 1 to 2 on my 2.7 (ex 320i 'box).I have a short shift as well! Next gearbox oil change I will try ATF.Has your lad changed the gearbox oil at all?
Posted: Mon Oct 15, 2007 1:48 pm
by neilboi
Yeah I try to leave it in gear but if it is too close to something in front or behind, I don't want to risk forgetting I put it in gear!
Thanks for help guys.
I am owner of the car by the way.
Posted: Mon Oct 15, 2007 2:01 pm
by kboiling
Thanks for this guys - yes gerabox and diff oil were changed about 3 weeks ago....
Re:
Posted: Mon Oct 15, 2007 2:44 pm
by tomson
It could possibly be the clutch is worn and not engaging properly till its warm ? ? ?
Posted: Mon Oct 15, 2007 3:55 pm
by kboiling
Thanks guys
We'll try new clutch fluid and bleed the system!
Re:
Posted: Mon Oct 15, 2007 5:12 pm
by bigkev
Mine has a new clutch , fluid and slave cylinder and also expensive fully synthetic oil and it has made bugger all difference , I think its just the oil being too thick when cold so I am going to try the ATF oil route next.
Re:
Posted: Mon Oct 15, 2007 5:15 pm
by fowler
i was think along the lines of slave cylinder not moving clutch enought to get into gear.
what about worn gear linkage and when warm operates correctly as heat in the area around the gearbox gets quite warm
Re:
Posted: Mon Oct 15, 2007 6:42 pm
by DanThe
You need some synthetic gear oil,
Posted: Mon Oct 15, 2007 10:44 pm
by Brianmoooore
kboiling wrote:Thanks for this guys - yes gerabox and diff oil were changed about 3 weeks ago....
This is probably the problem. Happened to me once.
It was probably ATF in the gearbox before, and you've replaced it with SAE80. Change it again for ATF.
