underpower 323i
stormhunt3r
Mon Sep 24, 2007 2:47 am
I'm driving a 323i and i notice is that my 323 isn't producing the power it claim to have. I've sent my car to a mechanic for checking and after he test drive my car, he too agree that it's a little underpower.
He then suggest that it might be the problem with the clutch and recommended to replaced it.
I think it could be the vacuum hoses which some had brittled and something to do with the tuning (i suppose it's related).
Could there be any other problem which you guys are aware of?
cheers
surj
Mon Sep 24, 2007 9:33 am
hi there dont really know how the old 323s work all vacum control idle and i got but swoppted mine with motronic manegement try the brass thing type of thing thats below the airflow meter arond 4 hoses go to this these things get stuk inside its something to do with the choke thats all i know hope that may help
chrisr29
Mon Sep 24, 2007 12:58 pm
Does it idle ok? If there's a vacuum leak it will idle like a dog.
May be worth checking the timing as well as you have to set it manually on those things. I had one myself.....they're not especialy quick anyway. Though it should feel fairly brisk above 4000rpm.
