Spray bar M20B25
Posted: Wed Aug 29, 2007 11:55 pm
by Jesus325iTouring
How do I check if it's operating properly?
I've no reason for suspecting anything otherwise,but if it's easy straight forward to do,I would like to check it all the same.
Cheers Geeeeeeeeeezah's
Re: Spray bar M20B25
Posted: Thu Aug 30, 2007 12:16 am
by 316eyes
I would think the only way to check would be visually. I'll leave the rest to your imagination!!!
Posted: Thu Aug 30, 2007 12:29 am
by Jesus325iTouring
316eyes wrote:I would think the only way to check would be visually. I'll leave the rest to your imagination!!!
Is it possible,do you know,to take the rocker cover off and start the car and see that way?
My imagination,at best,is sub-normal.
Posted: Thu Aug 30, 2007 1:08 am
by HairyScreech
i guess you could, its not like gallons of oil will suddenly burst everywhere drowning people and causing deformed babies that then have to live on ants and slugs and who will have more deformed babies um till the workd is full of deformed babies except the ones that run realy fast and they get diported to KENYA!!
my imagination is not-normal
i think so but be cairful of anything getting in there, have seen a rew things run with out the rocker cover on to check the rockers and lube jets so i cant see much of an issue.
Posted: Thu Aug 30, 2007 1:16 am
by Jesus325iTouring
Nice to meet other sub-normal people
Thanks for the advice too,will give it a go tomorrow.
Posted: Thu Aug 30, 2007 1:34 am
by intherealworld
take the rocker cover off when car is cold clean all oil off as many parts as you can get to, refit cover run engine for a while remove cover, if its got oil around all the spraybar holes and all the rockers then i wouldnt worry about it, its old pintos that starve the top end of oil through the spraybar
Posted: Thu Aug 30, 2007 11:39 am
by Andyboy
For what they cost, buy a new one. You can clean them out but there's always a chunk of shite in there somewhere.
Posted: Sat Sep 01, 2007 2:17 am
by Jesus325iTouring
Thanks for the replies fella's
Great help as usual
Posted: Sat Sep 01, 2007 6:23 am
by Hyperion
[quote="HairyScreech"]i guess you could, its not like gallons of oil will suddenly burst everywhere drowning people and causing deformed babies that then have to live on ants and slugs and who will have more deformed babies um till the workd is full of deformed babies except the ones that run realy fast and they get diported to KENYA!!
quote]
LMAO....classic!!
