Convertible Hood Repair
Wigsworld
Thu Aug 16, 2007 10:16 pm
Hi, would anyone know if there any companies in the London/south east area that specialise in repairing convertible hoods. My E30 convertible has an electric roof but the mechanism has become stuck, the electric motor is still working though. Any help would be greatfully apreciated.
Dan
Martinaston
Thu Aug 16, 2007 10:29 pm
Where is it stuck ?
Up, down, in a ditch ?
There is NO nucleus.
Wigsworld
Thu Aug 16, 2007 10:46 pm
When i go to put the hood down it won't move unless i force it, now the lid won't lift up on its own. I can still here the motor working though.
Martinaston
Thu Aug 16, 2007 10:48 pm
Does the rear window lift to let the cover come up ?
Wigsworld
Thu Aug 16, 2007 10:57 pm
No I have to lift it myself
Martinaston
Thu Aug 16, 2007 11:18 pm
Best not to keep forcing it then. Disconnect the motors from in the boot for now then lift the cover and see if the lever on the drivers side is bent/broken or both.
Wigsworld
Fri Aug 17, 2007 12:17 am
Ok mate thanks for you help.
DaveD
E30Zone Wiki Specialist
Fri Aug 17, 2007 12:16 pm
the motor might be working but I bet the casings broken
this site might explain more
http://www.e30ic.com/
you can buy new casings but do a search on hood motors
Wigsworld
Fri Aug 17, 2007 7:50 pm
Thanks for that mate, think my hood was just badly lubricated, now i've completly wrecked it!
Wigsworld
Fri Aug 17, 2007 7:58 pm
Would anyone know someone that converts electric hoods to manual ones?
Martinaston
Fri Aug 17, 2007 9:52 pm
If you have the manuel that comes with the car it shows you how to disconect the motors, use the rod in the tool kit and put it in the holes in the boot lining.
