obc fitting guide
gaszman
Wed Aug 15, 2007 7:20 pm
hi gonna get one for my tourer so i need a fitting guide any body got one cheers
maxfield
Wed Aug 15, 2007 7:21 pm
grantfk10
Wed Aug 15, 2007 7:31 pm
Any info on fitting the 6 button OBC/clock?
316eyes
Wed Aug 15, 2007 8:51 pm
grantfk10 wrote:Any info on fitting the 6 button OBC/clock?
6 button is a straight swap for the existing clock. Loom connects to the back of speedo pod and the gong. The other end goes to the outside temp sensor in the LH air duct.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Frenchy
Wed Aug 15, 2007 8:59 pm
Got the full monty 6 button one complete with stalk to change modes do i need to do anything else as mine came out of a 325i tourer?
Ie; Calibrate or similar for 4 pot?
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
darkchild
Wed Aug 15, 2007 10:35 pm
Frenchy wrote:Got the full monty 6 button one complete with stalk to change modes do i need to do anything else as mine came out of a 325i tourer?
Should be fine. The late 4 pot Lux models all had the 6 button OBC as standard.
Frenchy
Thu Aug 16, 2007 12:09 am
Cheers Ears,,,,,,,,,,Gerards Your Man!
gaszman
Thu Aug 16, 2007 3:38 pm
ok guys have obc fitted but do not have large box above ecu or horn ( guess any will do ) but tried to start the motor she wont start is this because i do not have relay box cheers
darkchild
Thu Aug 16, 2007 4:07 pm
gaszman wrote:ok guys have obc fitted but do not have large box above ecu or horn ( guess any will do ) but tried to start the motor she wont start is this because i do not have relay box cheers
You will need the relay control module that is attached to the ECU mounting plate for the OBC to function.
Cloggy Saint
Thu Aug 16, 2007 4:12 pm
The relay box is only there for the code function, everything else will work without it. Gaszman, do you have the 6 or 13 button model?
gaszman
Thu Aug 16, 2007 4:15 pm
13 button type but have noticed there another plug on the loom to the engine bay twin plug but i have no idea to what it plugs into
darkchild
Thu Aug 16, 2007 4:16 pm
datourer wrote:The relay box is only there for the code function, everything else will work without it. Gaszman, do you have the 6 or 13 button model?
I stand corrected. I thought you needed the OBC, loom and relay for it to work and the temp sensor, gong etc could be optional? I'll be fitting mine next week!
Cloggy Saint
Thu Aug 16, 2007 4:22 pm
for basic functions, time/date, av mpg/mph, stopwatch and maximum speed setting you just need the obc and loom. For the outside temperature you need a seperate loom going to the temp' sensor in the passenger side air-duct. The gong and stalk aren't really necessary but are nice to have.
nickso
Thu Aug 16, 2007 4:28 pm
there is a blank loop for part of the loom that is something to do with the code function/alarm bit. if this plug is missing the car wont start as it eventually feeds the coil and fuel pump.
the wires are green/red i think.
'88 e30 328i M52 track bint.
gaszman
Thu Aug 16, 2007 4:32 pm
have found this wire plug the wires back in as a loop starts sweet but i have a plug that has no where to go
this the loop plug but the one in the engine bay is diffrent any help
Cloggy Saint
Thu Aug 16, 2007 4:38 pm
It'll be the temp' sensor and/or horn. Nothing else goes to the engine bay.
nickso
Thu Aug 16, 2007 4:52 pm
temp sensor colours are blue and brown. the other one will be for the obc horn. you dont need it.
gaszman
Thu Aug 16, 2007 5:22 pm
ok will take pic but loks like h/lamp plug brown wires
gaszman
Thu Aug 16, 2007 5:41 pm
ok this plug is on the loom in the engine bay unless ive pushed to much through can anybody help
help please :o:
gaszman
Thu Aug 16, 2007 6:09 pm
just fitted the stalk and the com bit is working but now i have a light on the lead fron the stalk no idea what that does ??????
gaszman
Thu Aug 16, 2007 6:16 pm
ok guys to re cap have 1 yellow wire fron comp ? twin green pic 1 then plug in engine bay pic 2 any help cheers guys oh yes and the light on the indicator stalk ?
slinky2000
Location: Ireland - North(Portadown) and South (Limerick)
Thu Aug 16, 2007 6:27 pm
Is the engine bay plug not the horn?
I've also got the yellow from the back of the comp and no idea where to plug it and also the green one!
Cloggy Saint
Thu Aug 16, 2007 7:19 pm
datourer wrote:It'll be the temp' sensor and/or horn. Nothing else goes to the engine bay.
Like I said, horn or temp' sensor. As for the light on the end of the stalk...?? Got a picture? Slinky, the yellow plug goes into the empty socket on the back of the clocks.
slinky2000
Thu Aug 16, 2007 7:30 pm
na theres a two pin plug with a yellow wire coming from the back of the computer that's not plugged in, its only a short one, like under 10cm long.
Is that the same one gaszman?
gaszman
Thu Aug 16, 2007 8:18 pm
yes yellow plug but why the light on the indicator stalk lights up when you use the indicators is it to do with the alarm
tomtomiS
Thu Aug 16, 2007 8:29 pm
gaszman wrote:yes yellow plug but why the light on the indicator stalk lights up when you use the indicators is it to do with the alarm
wtf? there is no light on the indicator stalk
gaszman
Thu Aug 16, 2007 8:37 pm
ok hows this oh its a light
this is in the loom from the obc stalk
this is the little yellow one from behind the obs
this is the green wires two pin plug plugs into ?
and this wire is also on the loom but under the bonnet have also the temp sender and horn as well as this
tomtomiS
Thu Aug 16, 2007 8:50 pm
but its not a light actually on the stalk tho is it? it also looks too far over to be the abs warning light. have you by any chance knocked out the backlight for the heater fan speed control?
slinky2000
Thu Aug 16, 2007 8:51 pm
I dont think I've a light ...
gaszman
Thu Aug 16, 2007 8:52 pm
no its on the loom from the indicator obc stalk comes on well flashes when you use the indicators 1 flash then off strange
Chris-W
Thu Aug 16, 2007 8:54 pm
Odd tow-bar set up?
tomtomiS
Thu Aug 16, 2007 8:55 pm
ive not got that on mine, how bizarre! that really is strange!
slinky2000
Thu Aug 16, 2007 9:03 pm
what does the light look like? is it the white round thing?
gaszman
Thu Aug 16, 2007 9:08 pm
its above the cig lighter the lenght of the cable is 15" long
Cloggy Saint
Thu Aug 16, 2007 9:12 pm
Looks like one of the lamps for the light levelling system?
