Recon A Head
Posted: Sat Aug 11, 2007 12:10 pm
by isTURBO
Hi
I need to have the head on my 323i reconditioned.
It seems to be using oil and that has been put down to a need to reseat the valves etc.
1. Does anyone know approx what this should cost?
2. Anyone know of a place in Croydon that will be able to carry out the work?
3. Would there be a huge difference in cost if I flowed the head?
Any help would be greatly appreciated.
Re: Recon A Head
Posted: Sat Aug 11, 2007 12:18 pm
by pnd
Don't bother fit a used 325 engine cheaper and way better. gas flowing is a waste of money too on an m20 head plenty cash little gain. PRICE FOR RECONING HEAD INCLUDING REMOVAL AND REFIT HEADSET ETC AROUND £600
Re: Recon A Head
Posted: Sat Aug 11, 2007 12:30 pm
by Templ8e30
Reseating the valves won't stop it using oil.
The valve stem oil seals may well be shot, usual symptoms are burning oil on startup.
If it's burning oil all the time or when given some revs it's usually down to worn piston rings.
Either way it'll cost £Â£Ã‚£ if you don't do it yourself.
The parts aren't too expensive but the labour will be.
Cheers,
Iain T
Re: Recon A Head
Posted: Sat Aug 11, 2007 2:06 pm
by Brianmoooore
Exhaust valve guides are the usual culprits, and are cheap to replace.
Look up FER (federation of engine rebuilders or reconditioners) and find a member local to you.
Get them to check out the head and do what is necessary. Usually replace exhaust valve guides, reface, reseat and lap in all valves, plus a light skim.
Including all gaskets, usually comes to about £300.
Re: Recon A Head
Posted: Sat Aug 11, 2007 6:34 pm
by pnd
Including all gaskets, usually comes to about £300. if thats for refitting as well as reconditioning there must be some skint mechanics near you Brian.
Re: Recon A Head
Posted: Sat Aug 11, 2007 6:39 pm
by reaz12345
i just had my clylinder head recond at bensham enginering in croydon there of london raod near the old philips building 0208 6844126 ask for andy tell him yr reaz mate hill sort u out. plus there the best in croydon every1 knowns about them
Re: Recon A Head
Posted: Sat Aug 11, 2007 6:56 pm
by Brianmoooore
pnd wrote:Including all gaskets, usually comes to about £300. if thats for refitting as well as reconditioning there must be some skint mechanics near you Brian.
I remove and strip the head. It comes back to me with just the valves fitted.
Re: Recon A Head
Posted: Sat Aug 11, 2007 10:12 pm
by isTURBO
Cheers Guys
Thank you for the info.
I will check out Bensham Engineering on Monday.
Thank you once again guys
Re: Recon A Head
Posted: Sun Aug 12, 2007 12:30 pm
by wrobstar21
I got one from bridge cylinder heads fully recon but not welded, for £395 warrented for a year. Spot on it has been so far. Id do that if i were you, if yours is shot! id say the worst bit on doing mine was getting to all the nuts and stuff but other than that quite straight forward. And prepare your block!
Re: Recon A Head
Posted: Mon Aug 13, 2007 3:57 pm
by isTURBO
reaz12345 wrote:i just had my clylinder head recond at bensham enginering in croydon there of london raod near the old philips building 0208 6844126 ask for andy tell him yr reaz mate hill sort u out. plus there the best in croydon every1 knowns about them
thanks for that Reaz
Andy knows you really well and has a lot of time for e30's not to mention a wealth of knowledge.
He has been really helpfull and was asking about you and how did your motor get on.
