Water leak
Posted: Thu Jul 19, 2007 9:47 pm
by raulandthetwins
My 320 has sprung a leak a large pool of water appeared under the front on the nearside, it seems to drop from above the fog light and there is a wet patch just behind the head cover, it doesn't appear to have lost an coolant or screen wash! i'm stumped?
Also after driving the water is cold so must rule out coolant??????
Help please :mad:
Re: Water leak
Posted: Thu Jul 19, 2007 10:13 pm
by jcjdavis1
Hi do you have intensive wash system,if so maybe a water pipe has come of and water coming from that.
Re: Water leak
Posted: Thu Jul 19, 2007 10:18 pm
by raulandthetwins
What do ya mean intensive wash system, all screen and head lamp wash jets are all still working???
Re: Water leak
Posted: Thu Jul 19, 2007 10:49 pm
by Brianmoooore
If it has headlamp washers, then the white backcheck valve (in the pipe, six inches from the jet) has probably failed, and the water is coming out the vent hole.
Re: Water leak
Posted: Thu Jul 19, 2007 11:19 pm
by raulandthetwins
Your right!!! grille and wipers off unplug jet and press washers on and it pisses out the white valve
Cheers :D
Re: Water leak
Posted: Thu Jul 19, 2007 11:26 pm
by Brianmoooore
zimmerbimmer1 will supply you with a new one. About £3, IIRC.
