fitting breyton rear skirt.
Posted: Sun Jul 15, 2007 10:16 pm
by 1an
i needs some advise on fitting a breyton rear skirt.
whats the best way to go about this?
take the back bumper off? or do it with it still mounted to the car?
cheers ian
Re: fitting breyton rear skirt.
Posted: Sun Jul 15, 2007 10:23 pm
by essexboy
by Dan318-is
Run away!!
not really mate, your one of the lucky ones! with the front the bumper has to stay on from my experience. On the rear i think you can take it off though; bumper bolt access might be a bit fun though?
PM simon13, he has one on his council dynamics ringmeister an it hasn't fallen off yet!
Posted: Sun Jul 15, 2007 10:29 pm
by matt1980
The way mine is fitted you will need to remove the bumper by unbolting the the 4 nuts that hold the mounting brackets to the rear pannel, (not the 2 allen bolts from underneath as you would usually when removing the bumper as with the lip fitted you will not be able to access the bolts to bolt the bumper back on). At this point you can postion the lip and secure it to the car with either self tapping screws or rivets. Finally refit the bumper. 3 of the 4 bolts that hold the bracket on are accessed from under the car and one is accessed from inside the boot (drivers side). The 3 under the car will probably be seized on so soak them in penatrating oil or heat them up to free them off.
Posted: Sun Jul 15, 2007 10:30 pm
by 1an
by the looks of it dan i should be able to get the torque piece in there on a ratchet (i think thats how the bumber comes off.
next decission is the colour? calypso or satin black.
and guess what lee i aint selling it
Posted: Sun Jul 15, 2007 10:33 pm
by essexboy
didnt want it anyway!!!!
by Dan318-is
yes ian those are the two bolts that hold on the bumper; T55 torx type. If you can access them with the bumper on there than take it off and fit it, will make life much easier.
Calypso red i reckon?
Matt got any pictures of yours on?
Posted: Sun Jul 15, 2007 10:36 pm
by 1an
im thinking calypso,
needs to go get a fibreglassing kit tomorrow as the one i got of spadge is cracked but it was cheap
could you get a pic up for me please matt of yours fitted on there,
ill go take the bumper of tomorrow.
and doesnt it just clip on like the iS lips?
Posted: Sun Jul 15, 2007 10:45 pm
by SPADGE
Posted: Sun Jul 15, 2007 10:51 pm
by 1an
i did tell you what is was worth, but in my opinion it was a bargin
whats the best way to fit it spadge?
Posted: Sun Jul 15, 2007 10:55 pm
by matt1980
[img][img]
http://i56.photobucket.com/albums/g189/ ... arside.jpg[/img][/img]
Re:
Posted: Sun Jul 15, 2007 10:57 pm
by 1an
decission made, its gotta be colour coded.
am i seeing things matt but arent they tech1 skirts a facelift? looks nice though
Posted: Sun Jul 15, 2007 11:00 pm
by matt1980
Yea they are, that pic is from when i bought the car an im currently sorting out and de chaving it lol so ignore the yellow calipers/drums and lack of a front lip etc.
Re:
Posted: Sun Jul 15, 2007 11:01 pm
by 1an
got ya, so the breyton rear skirt is easy to fit with the bumper of then?
Posted: Sun Jul 15, 2007 11:07 pm
by matt1980
Yea its a simple job with the bumper off, just dont forget that you cannot access the 2 allen bolts that hold the bumper on with the lip in place, but if you do it as I described its very easy.
Re:
Posted: Sun Jul 15, 2007 11:09 pm
by 1an
ok so what bolts do i need to undo to get the bumper of, witha quic glance early there are 2 big torque headed bolts are there others>?
Posted: Sun Jul 15, 2007 11:13 pm
by matt1980
If the torque head bolts are the 2 you can see looking up at the bottom of the bumper then you need to ignore them as you cannot get them back on with the lip in place. Insted you need to remove the 4 nuts that hold the brackets to the body shell that the 2 torque head bolts go through(if that makes sense)?
Posted: Sun Jul 15, 2007 11:22 pm
by matt1980
[img][img]
http://i56.photobucket.com/albums/g189/ ... -adj01.jpg[/img][/img]
Ignore the arrowed bolts insted remove the nuts that hold the brackets on that those bolts fasten to. You can see the black bracket behing the bumper its the nuts that hold that to the shell you need to remove.
Posted: Sun Jul 15, 2007 11:38 pm
by SPADGE
1an wrote:i did tell you what is was worth, but in my opinion it was a bargin
I know mate i was happy to let you have it cheap as i knew you wanted one and because the skirts wern't as mint as i thought. I was joking above lol
I removed it with the bumper on but it was tight so remove the bumper as has been mentioned above .
Posted: Mon Jul 16, 2007 9:31 am
by 1an
that clears that all up then, now i know how to remove it, i think ill attach it to the bumper and then fibre glass the crack and spary it up so the bumper match the skirt.
cheers everyone for the advise.
