hi,
325i sport
i have a high pitch wine when on idle, gets worse the more you you rev it up. the alternator and powersteering belts are tight. mayb waterpump, any surgestions?
cheers
mayb water pump?
- Brianmoooore
Take each belt off and run the car for half a minute to narrow down the source of the noise.
Doubt if it's the water pump. They don't normally whine.
Jesus325iTouring
- Frog freak !
It's not the missus is it?wise wrote:hi,
325i sport
- Brianmoooore
Noise goes when the alternator/pump belt is removed, so it's not the cambelt.gazza wrote:have you recently fitted a cam belt and idler ....if the idler has been tensioned up to tight the belt can whine a bit or maybe its time to do a cam belt before it goes on you
However, I'd recommend changing the cambelt when the water pump is replaced, as the tensioning spring locates against the water pump.
