Instrument cluster
Posted: Fri Jul 06, 2007 12:46 am
by jim_sohal
been having some probs recently, my rev counter began to play up (sometimes it worked sometimes it didnt) so i gave the dash a few knocks and so the rev counter began to work again but wuz still a little dodgy but now the MPG and the temp needles have also stopped working, anybody have any ideas as to what i need to do??
Re: Instrument cluster
Posted: Fri Jul 06, 2007 1:42 am
by tailoutcharlie
wait for brian to notice this thread
but in the meantime read this
at least it will tell you how to get in there and have alook
HTH
Posted: Fri Jul 06, 2007 3:03 am
by dj888
if replacing the batteries in your SI board won't help, i understand there's a by[ass and direct line to your alternator for your rev counter. it's the one that has a flat socket.
Posted: Fri Jul 06, 2007 5:16 am
by jcjdavis1
Hi Go to breakers buy cluster then swap SI Boards.After you have done that sell remaining bits from cluster to recoupe initial cost.
Posted: Fri Jul 06, 2007 9:29 am
by Brianmoooore
SI batteries. Use the search function to see how to change them, or raid a scrappy for a SI board with lithium 3 volt batteries.
Posted: Fri Jul 06, 2007 12:10 pm
by jim_sohal
Cheers guys for your responses, I just wanted to give a bit more detail: basically when i said the MPG and temp stopped working the funny thing is they actually move when i turn the ignition which shows me that there not completely dead (the MPG moves to about 10 and stays there and the temp moves up to just touching blue n stays there) As most of u suggested batteries im thinking that this wudn't happen if batteries needed replacing and the needles wud simply stay dead??? Mayb i shud change the whole cluster like jcjdavis says???
Posted: Fri Jul 06, 2007 1:12 pm
by Brianmoooore
Change the whole cluster if you like, but a SI board (or two) fits in the bottom of your tool box in the scrappys in a way that a complete cluster won't!
