Quick question on rear ride height
Posted: Sat Jun 30, 2007 5:50 pm
I'm currently running some spax (non-adjustables) shocks and springs on a 60/40mm drop on my 4dr 325i SE. I don't have any rubbing problems on the rear but I want to drop it another 20mm. I'll more than likely just cut a coil off each of the rear springs.
Only problem is I've got some quite a bit of camber and toe in already. I'm not sure of what to do regarding lowering it a bit.
I've also heard that 60/60 drop will change the handling negatively as oppossed to 60/40.
Woo that's a fun read
