4 stud to 5 stud conversion
Posted: Sun Jun 24, 2007 9:17 pm
by KINGOFSNAKE
can i change my e30 325i wheel thingys to accept my five stud e36 330 18" wheels, please make any answers simple because im still learning :twisted:
Re: 4 stud to 5 stud conversion
Posted: Sun Jun 24, 2007 9:52 pm
by Brianmoooore
Simple answer is fit M3 E30 suspension.
Posted: Sun Jun 24, 2007 9:53 pm
by whipsey
i've found a breakdown for this using e36 compnents i'll send you the link when i get my internet back on tuesday
Posted: Mon Jun 25, 2007 12:31 am
by dasparkybad
Thats only a simple answer if you can find some e30 m3 suspension
http://lukasmotors.com/m_roadster_5_lug_swap.htm
the guy in the link used z3m parts you can also use e36 front legs and e36 compact rear trailing arms for this conversion which are a lot easier to find at a breakers yard hope this helps
Posted: Mon Jun 25, 2007 12:52 am
by KINGOFSNAKE
cheers , any help is appreciated. the m3 option sounds expensive, but you never know
Posted: Mon Jun 25, 2007 3:08 am
by Jhonno
from the sounds of it tho, best left well alone..
total and utter waste of time just to fit different wheels
Posted: Mon Jun 25, 2007 4:21 am
by sidewaysjon
would this not be easier and cheaper, a lot cheaper
http://cgi.ebay.com/ebaymotors/BMW-4-LU ... enameZWDVW
Re:
Posted: Mon Jun 25, 2007 8:03 am
by KINGOFSNAKE
thanx for all the replies, my suspensions shagged so ive got to change it, and my e36 (which i dont like that much)
has these beautiful wheels on from bmw almost alpina style so i would like to keep them. the convertor mentioned
by sideways jon sounds perfect. if you listen carefully you can hear me reaching for my tape measure to see if that way is possible :D
Posted: Mon Jun 25, 2007 8:55 am
by Brianmoooore
sidewaysjon wrote:would this not be easier and cheaper, a lot cheaper
it's your neck you'll be risking (plus those of the odd pedestrian and other motorist).
Re:
Posted: Mon Jun 25, 2007 10:02 am
by KINGOFSNAKE
not quite sure what the last message meant, :?:
Re:
Posted: Mon Jun 25, 2007 12:41 pm
by Jhonno
there is a major difference between changin the suspension and a 5 lug swap.. seriously, step away, its for the best
Re:
Posted: Thu Jun 28, 2007 10:39 am
by whipsey
