E36 Injectors into an E30???
Posted: Sun Jun 24, 2007 8:57 pm
by funky-monkey
I was wandering if anyone had done this? As the E30 325i injection system is getting on a bit now. Does anyone know if I could replace my current injectors with a lot from an E36 325i to maybe get a bit more power and make the system a wee bit more efficient?
Re: E36 Injectors into an E30???
Posted: Sun Jun 24, 2007 9:00 pm
by oakey
afraid not mate :( the engine wont make use of the extra fuel
Posted: Sun Jun 24, 2007 9:02 pm
by funky-monkey
shame, though if you don't ask you don't get. Thanks :)
Posted: Sun Jun 24, 2007 9:06 pm
by KINGOFSNAKE
some bloke on ebay said it was a good upgrade option, im glad you asked the question so now i wont be fooled :)
Posted: Sun Jun 24, 2007 9:15 pm
by funky-monkey
I saw the same add.
Posted: Sun Jun 24, 2007 9:22 pm
by march109
all a load of bolocks they won't help at all, infact you'd probably run rich. the Egay fella doesn't know what hes talking about.
Posted: Sun Jun 24, 2007 9:42 pm
by Simon
funky-monkey wrote:I saw the same add.
I saw it too, pretty sure it was a zoner too, Danthe, was wondering the same myself, as I have some M50 injectors from a 525i here.
Posted: Sun Jun 24, 2007 9:48 pm
by oakey
Im running larger injectors on mine and they didnt make the slightest bit of difference
Posted: Sun Jun 24, 2007 10:06 pm
by DanThe
Yes its my ad :o:
Got a fair few sets I need to get rid of one way or another.
If you read closer though you will notice I recommend them for turbo or cc increased engines, no bullshit anywhere :wink:
Posted: Sun Jun 24, 2007 10:09 pm
by DanThe
Heres the link for all the 'slaters' :)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
Posted: Sun Jun 24, 2007 10:13 pm
by funky-monkey
No slating intendid, I'm just not that technical and I am always looking for ways to make my car that little bit better. It's all good :)
Posted: Sun Jun 24, 2007 10:26 pm
by DanThe
Well you did the right thing in asking on here :wink:
Posted: Sun Jun 24, 2007 11:26 pm
by HairyScreech
iv been told that the ecu isnt a learning type and that injectors or a different flow rate. either hiher or lower cc/min, will cause it to over or under fuel and need adjustment.
if thats wrong then im sure in the market for a new set of injectors for the m20b20.
Posted: Mon Jun 25, 2007 12:15 am
by DaveD
I have a set in my garage too and am pondering whether to fit them...I am lead to understand that if you have a lambda sensor the ecu will compensate for the possibility of a too rich mixture??
Posted: Mon Jun 25, 2007 12:22 am
by Kos
look at it this way if you feed a horse more food will it run faster ??
Posted: Mon Jun 25, 2007 12:27 am
by DanThe
:lol:
Posted: Mon Jun 25, 2007 12:30 am
by Hath
Kos wrote:look at it this way if you feed a horse more food will it run faster ??
depends if you put steroids of sort in there..
Posted: Mon Jun 25, 2007 12:31 am
by DaveD
no ................its gets fatter! :D
Posted: Mon Jun 25, 2007 12:35 am
by HairyScreech
you wont bee feeding it any more as the fueling has to be adjusted to suit otherwise it will just be running ritch.
lamba sensors been mentioned before, theory is it wont have a wide enough adjustment range to compensate. but this is yet to be tested.
Posted: Mon Jun 25, 2007 12:59 am
by oakey
standard injectors are good for well over 200hp. so unless you are planning on running more power than that using anything larger than standard injectors is not going to give a noticeable power gain?
Posted: Mon Jun 25, 2007 11:47 am
by Kos
its the easiest way to make people understand
train the horse and give it the right things then it will get faster and stronger
Posted: Mon Jun 25, 2007 4:21 pm
by kam-325i
DanThe wrote:Yes its my ad :o:
It was me that emailed about the M50 injetcors having a greater flow rate.
Posted: Mon Jun 25, 2007 5:15 pm
by ed325i
I used e36 m3 injectors in my cab and it didnt make any difference.
Posted: Mon Jun 25, 2007 9:38 pm
by --alpina--
I have E36 M3 injectors in my car, the spray pattern is different, you will notice that when fitting the injectors it will over fuel, but take your car for a C02 adjustment back to how the previous injectors were, i done this cos i was the one who took the injectors outta the engine and it only had 3k miles on the clock and my injectors are new so i thought why not put em in, never looked back and had no problems... you can fit E36 2.8 injectors, M30 3.5 injectors, and ive know people to do that and works well.. im not condoning it as you can make your own mind up but like i says ive had no problems and the car runs sweeet, bear in mind i have a 2.7 reemapped with them on.....
goodluck
